2002 si sway bars.
sway bars.
my friend just upgraded his sway bars on his 2002 si. i have a 1993 LX sedan.
any way i can make these fit? or should i try to sell them, give them back ?
also, does anyone have sway bars that will fit a 1993 sedan?
Modified by STREETWERKZ at 4:03 PM 4/24/2004
Re: 2002 si sway bars. (STREETWERKZ)
nobody??? had to change title to SWAY BARS from 2002 sway bars, cuz i figured non of you would look at it.
can anyone help?
can anyone help?
Why don't you get under your car with the swaybar and check to see if it will fit? It's not exactly like a swaybar is a complicated install
Re: 2002 si sway bars. (GetawayinMoscow)
I know it wont fit, i'm seeing if there is a way to MAKE it fit.
or if anyone has some that do fit. JEEZ.
It wont fit, the way the bar bends is just way off. Anything under 2001 integra or 2000 civic will fit since they were wishbone suspensions. Even if you could make it fit, it might not work correctly. The place where the endlinks connect to the LCA are different places.
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">I know it wont fit, i'm seeing if there is a way to MAKE it fit.
or if anyone has some that do fit. JEEZ. </TD></TR></TABLE>
yes there is a way to make it fit. i doubt its worth the time. jus get a type R bar easier and bigger.
honda93
09-05-2006 06:39 PM
alwaysoverkill
Suspension & Brakes
02-12-2006 08:14 PM
AEGEAN
04-02-2003 11:56 AM
