I need a crome basemap!
Hey I have everything i need. crome, moates chip burner and chipped ecu. Here is the list of my build
b16a3 on e85
15psi of boost
nippon 8.5:1 pistons
1000cc injectors
gm 3bar map sensor
If anybody has a similar build and has a basemap available please let me know i would really appreciate it
b16a3 on e85
15psi of boost
1000cc injectors
gm 3bar map sensor
Here is a good place to look around for base maps. http://www.xenocron.com/bins/
You mentioned that you have everything, I notice you didn't mention datalogging or a wide band O2. What tuning method are you going to use to monitor your engine?
Don't just throw any old downloaded basemap onto a chip without first looking at all of the maps, options and settings. Also remember that just because it ran one engine doesn't mean it will run yours.
I am fully aware of this. I do not have datalogging or a wide band. I just need a basemap in order to get me to the shop to have it dynotuned is all. But a good basemap from someone with a simular set up will get me there.
But thank you I will check your link
http://www.xenocron.com/chipping-basemaps-c-23_54.html
quartermilerun
Engine Management and Tuning
Jan 20, 2013 09:30 PM
sherwooddc2
Dec 3, 2009 06:37 PM
92gsrteg
Aug 2, 2005 01:03 PM
