brake pedal loses pressure
i relplaced my master brake cylinder and when i brake its like i loose pressure in the brakes i bleed the brakes a few good times its a 95 vx civic and i dont know if my rear disc were upgraded to gsr or their civic ones if that matters
havent checked the prop valve see i bought the car already with rear disc but i thought vx didnt come with rear disc but correct me if im wrong ..........and no i didnt bleed in the proper order i need to look up the order to do that
Helms manual states bleeding order as Back right, Front left, Back left, front right....because the brakes are linked diagonally.
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Get this inexpensive bleed tool:
http://www.amazon.com/gp/product/B00...ZJVZJDCP53P00X
Always start furthest away from the master cylinder, and the diaganol split should not matter but i could be wrong.. And the only problem with that tool is you can't see if you have got all the air out. Two people is always better then one.. And besides you only need a pop bottle, paperclip, and 18inchs of brakeline in place of that tool. Lol
The tool costs only $4, is very convenient, does not require a buddy, and prevents air return to the system. For each wheel, just pump the pedal until the bottle fills and you should be good to go.
Oh, I agree completly, I have one of those as well as a vacume bleeder. I was just being a smart ***. Lol. But I don't trust anything except the two man method on a cutomer car.. To each his own though.
that bleed tool is awesome. I flushed all 4 wheels and complete brake system in 30 minutes. Still had brake fluid left over so I flushed my clutch too
00siandrew
Aug 6, 2008 09:15 PM
byronl
Jan 22, 2008 12:55 PM
EJ1 wilcox
Apr 21, 2006 08:51 AM
