Why does the brake pedal have no pressure?
Old May 20, 2003 | 08:22 AM
TedR719's Avatar
Default Why does the brake pedal have no pressure?
What are some reasons that the brake pedal would lose pressure?
Master Cylinder?
Brake Booster?
When the car is off and you pump the pedal it gains pressure rather than going stright to the floor.
Old May 20, 2003 | 10:47 AM
JimBlake's Avatar
Default Re: Why does the brake pedal have no pressure? (futuresi)
Sounds like air in the brake lines. Bleed your brakes. If that doesn't help, then maybe you need a master cylinder.
Is the fluid leaking out anywhere? Does the reservoir stay full?
When the car's running, does it pump up also (like when it's off)?
Old May 20, 2003 | 12:41 PM
TedR719's Avatar
Default Re: Why does the brake pedal have no pressure? (JimBlake)
We did bleed the front brakes but did not do the rear, going to re-do it right.
I notice some fluid coming from the m/c area when I was replaceing the front passenger side suspension, when I was moving the caliper there was some fluid that leaked out when there was some pressure. The reservoir does stay full.
When the cars running there is no pressure in the pedal, it still stops but the pedal is pressed all the way down...
Old May 20, 2003 | 01:04 PM
gsrclan's Avatar
You should not bleed the front alone, it should be done diagonally, rear right first then front left, then rear left and finally front right.
Old May 20, 2003 | 01:10 PM
orange.honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futuresi &raquo;</TD></TR><TR><TD CLASS="quote">
When the car is off and you pump the pedal it gains pressure rather than going stright to the floor.</TD></TR></TABLE>
this is what is supposed to happen. if the car is off and you pump the pedal it should get really hard. this is bc you are draining the vacuum out of the brake booster, and are not being helped out by it. if this is what is happening then you are fine.
Old May 20, 2003 | 02:40 PM
Behan's Avatar
Default Re: Why does the brake pedal have no pressure? (gsrclan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrclan &raquo;</TD></TR><TR><TD CLASS="quote">You should not bleed the front alone, it should be done diagonally, rear right first then front left, then rear left and finally front right.</TD></TR></TABLE>
you should bleed the brakes furthest from the master cylinder first. then 3rd furthest, 2nd, etc.
Old May 20, 2003 | 04:39 PM
Lord Helmet's Avatar
Default Re: Why does the brake pedal have no pressure? (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">
you should bleed the brakes furthest from the master cylinder first. then 3rd furthest, 2nd, etc. </TD></TR></TABLE>
well honda does it kinda weird. honda helms manual states you start from the right rear corner then left front corner, then left rear corner and finally the right front corner. it's suppose to be in a diagonial pattern. it weird for me the first time I did it according to the helms manual but hey that's what honda wants.
Old May 21, 2003 | 05:24 AM
JimBlake's Avatar
Default Re: Why does the brake pedal have no pressure? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">... it's suppose to be in a diagonial pattern. it weird for me the first time I did it according to the helms manual but hey that's what honda wants.</TD></TR></TABLE>
Diagonally opposite wheels are on the same circuit. You usually do them right after each other, 'cause if you wait too long then bubbles can move back into the one you just did.
Check a manual for YOUR CAR, because they're not always the same. Especially with ABS. My 3 cars all have different bleeding orders, because the plumbing for the brakes aren't all the same.
The order should be based on which one is more likely to let bubbles move into which other one. If you do them in the wrong order you might have to go around a couple times before all the bubbles are out.
Old May 21, 2003 | 07:54 AM
TedR719's Avatar
Thanks for the replys. I will tell him to re-bleed the brakes correctly and then see what happens after that.
jdmland
11
May 1, 2010 08:45 PM
draperj09
17
Oct 18, 2007 03:03 PM
Turbo-Honda
Suspension & Brakes
Jan 11, 2007 08:22 PM
crx1856
Aug 17, 2003 04:26 PM
Driven
May 26, 2003 03:29 PM
