t25 turbo question
Old Aug 16, 2010 | 11:23 AM
ef_hatch_boy's Avatar
Default t25 turbo question
hi i just got a garret t25 bc1 m27 a/r .48 turbo and im trying to put it on my 91 civic which the motor was swapped to a 92-95 d15 vtec motor my problem is that the turbo came with an internal wastegate and all manifolds i find have a wastegate flange how can i make this work can i put another wastegate or should i just fabricate a block off plate for the wastegate flange if its even possible or how would i be able to do this thanks for your time
Old Aug 16, 2010 | 11:36 AM
96gts4.6l's Avatar
Default Re: t25 turbo question
You might try posting this on a more knowledgable site...
Old Aug 16, 2010 | 11:48 AM
which site should i go on cause i got this all sitting here and if i dont do nothing in 3 days im selling it
Old Aug 16, 2010 | 01:34 PM
92egdxhatch's Avatar
I've seen wastegate blockoff plates. If you can't find one make one. It's just cutting sheet metal drilling holes and bolting on and sealing.
Old Aug 16, 2010 | 03:20 PM
so it will work if i just block it off
Old Aug 18, 2010 | 08:47 PM
AintIfresh_EF9's Avatar
try checking with your local muffler shop maybe they can fabricate a block of plate for cheap and it should work.
Old Aug 18, 2010 | 11:03 PM
ef_cowboy's Avatar
just get a stock ex. manifold with a pre cat...hf maniifold,i dnt know what other will work
Old Aug 19, 2010 | 12:28 AM
My_EFsedan's Avatar
block it off..
http://www.atpturbo.com/mm5/merchant...egory_Code=WGT
Old Aug 19, 2010 | 06:14 PM
Post some pictures of the set up once it's complete.
Old Aug 20, 2010 | 09:07 AM
EsotericImage's Avatar
Retired Moderator
theres block off plates cheap on ebay.. I think i have one laying around in my garage..
Old Aug 20, 2010 | 09:34 AM
zx636d6f's Avatar
You can block it off, that wont be a problem.
BUT....does your o2 housing have a wastegate port?
Old Oct 17, 2010 | 06:04 PM
thanks guys appreciate the help
EKris
Mar 30, 2009 01:08 PM
xfletcherxx
Jun 15, 2006 06:22 PM
Novtecdohc
Jun 16, 2005 08:30 AM
hcivic99
Jan 23, 2005 04:31 PM
mrsurfermike2001
May 15, 2003 10:01 AM
