D16z6 major problems
well, after we did a D16z6 swap, things were great, until the headgasket was leaking oil.. turns out the headbolts werent torqued right.
I replaced the headgasket and bolts, hooked everything back up, i can feel the car have a bit more power than it used to, but now its leaking coolant somewhere, from which i cannot see, and it leaks a decent amount, to where the car almost overheats. The CEL comes on, and just before start-up, it flashes once long.
most likely your head is warped. you NEED to have it resurfaces EVERYTIME. I can almost bet that's your problem. Yea it can cost up to $100 bucks but it always worth it. I've changed plenty of civic head gaskets and not once i haven't had the head resurfaced and pressure testing it ensures that your valve seals aren't leaking which can cause oil loss.
woww, honda makes cheap parts i guess lol.. i never had to do that with my Stealth's cylinder heads.
so if i resurface the cylinder head, what about the surface on the engine block?
the block should be fine, i just did the head on my 95 ex which is D16z6 also and i couldn't believe how bad the head was warped, but since i did it my car has ran perfect
i suggest using 600-800 grit sand paper on the block though, don't sand alot just enough to remove all the build up. Scraping the block really good with a razor blade wouldn't hurt either. just remember to use a new clean cloth to wipe everything down before installing the new head gasket, and torquing the head down is a 2 step process do exactly as it tell you in the book and there shouldn't be any problems.
alex-eh6
Jan 26, 2009 12:24 PM
apexrift
Jan 28, 2005 11:04 AM
