Terrible engine whine after sub/amp install.. HELP!
Old Sep 16, 2002 | 06:50 PM
ITR #0202's Avatar
Default Terrible engine whine after sub/amp install.. HELP!
I installed a single ten in my ITR. I ran the power wire down the right side under the sill and under the ECU. The RCA's, RF Cable for changer, and switch wire for amp are ran down the center of the car under the console. I did the same thing in my GSR Sedan and had no problems at all.. In the ITR I have very bad engine whine coming from the sub. PLEASE help! Any assistance is greatly appreciated. Thanks in advance..
-Frank
Old Sep 16, 2002 | 06:53 PM
Eric R's Avatar
Default Re: Terrible engine whine after sub/amp install.. HELP! (ITF KNR)
Normally, sub woofer installs shouldn't reproduce engine noise.
Check the crossover in the amp and make sure it is in low pass mode.
Old Sep 16, 2002 | 06:57 PM
BlueR's Avatar
Default Re: Terrible engine whine after sub/amp install.. HELP! (Tweety R)
check your ground...try to relocate to a better spot
Old Sep 16, 2002 | 06:59 PM
ITR #0202's Avatar
Default Re: Terrible engine whine after sub/amp install.. HELP! (BlueR)
damn, you are right. thanks! I forgot about bad ground causing that.
Old Sep 16, 2002 | 07:01 PM
BlueR's Avatar
Default Re: Terrible engine whine after sub/amp install.. HELP! (ITR #0202)
try to find a clean spot where the are no welds or bonding material
Old Sep 16, 2002 | 08:03 PM
ITR #0202's Avatar
fixed. thanks.
Old Sep 16, 2002 | 11:19 PM
Calavera's Avatar
fixed. thanks.
Where did you ground it too? Did you switch the ground wires near the headunit as well, or just the amp?
Old Sep 17, 2002 | 04:36 PM
ITR #0202's Avatar
Default Re: Terrible engine whine after sub/amp install.. HELP! (Calavera)
I grounded the amp to the rear crossmember under the seat. It was not the ground that was causing the whine, it was the damn amplifier. I had the X-over on hi-pass instead of low-pass. Pressed one button and fixed the entire problem. I was mad too, since I could have saved about 3 hours of work.
Old Sep 19, 2002 | 12:44 PM
Resurgent's Avatar
a LA GrOuNd LOOP
Stock90Civic
Audio / Security / Video
Mar 14, 2009 11:24 AM
r1ch1e
Apr 12, 2007 09:56 AM
Agent Daimon
Jan 13, 2003 09:40 PM
sedantegrida
Jul 4, 2002 11:54 AM
raene
Jul 23, 2001 01:44 PM
