The T3/T4 57 Trim Turbo Thread... or 50 or 60
Old Aug 1, 2010 | 01:50 PM
CRXherbie91's Avatar
Default The T3/T4 57 Trim Turbo Thread... or 50 or 60
The 57 trim is a very popular turbo i am very curious what kind of power people are making, i have it but not on my car just yet, .. i would love to hit 500whp however my 57 will not hit it.. but i would be happy with 425-450whp.. im trying to see what kind of power people are making with this turbo on pump gas .. i have 93 in my area.. and what is your engine set-up would be nice too.. mine is a b16 fully built head an block..
Old Aug 1, 2010 | 02:24 PM
littlewagon's Avatar
Default Re: The T3/T4 57 Trim Turbo Thread... or 50 or 60
Also curious.
Old Aug 1, 2010 | 02:57 PM
b16bri's Avatar
I had a fully built b16a with a full-race mani and t3/t04e 57 trim i dynoed a little over 400whp on a low reading dyno at 20psi of boost. I would have made more but i lost some power due to the cams i was running. it also made 310 for tq
Old Aug 1, 2010 | 04:34 PM
ls_on_boost's Avatar
i had a str8 ls made 419whp 306tq 22psi on e85 but i had a 70 ar cp 9:1 eagle rods
Old Aug 2, 2010 | 03:25 AM
non-VTEC's Avatar
b20/vtec 9.5:1cr, ported B16 head and blox type-a cams. 440whp+@16psi
im positive i can hit 500whp with that turbo but it's defiantly pushing it's limits and i don't want to risk it...
Old Aug 2, 2010 | 08:18 AM
TheShodan's Avatar
Moderator
500 would be very brief, only the last hundred rpms, and you would need to keep timing down to do it because of so much heat.
The 57,60 "trims" can do up to about 430whp or so. Any dyno that says otherwise has been calibrated to read "high".
Old Aug 2, 2010 | 04:26 PM
IN VTEC's Avatar
81.5mm, 57 trim, 450whp on pump gas
Old Aug 2, 2010 | 05:31 PM
TheShodan's Avatar
Moderator
Originally Posted by IN VTEC
81.5mm, 57 trim, 450whp on pump gas?
I'm sorry, but I'm extremely skeptical to remotely believe this
Old Aug 2, 2010 | 07:15 PM
IN VTEC's Avatar
It didn't last long after we had a lean moment on a cold night. It might have even done a little damage before that because it had a lot of blowby.
Old Aug 3, 2010 | 02:49 AM
miguel329's Avatar
375 @ 17 psi on t3/t04e 60trim built benson?sleeved gsr block..
Old Aug 3, 2010 | 05:45 AM
extremeracer's Avatar
470whp on Methanol @ 20 psi (derived from weight and trap speed) Super 57trim with stg 5 turbine wheel 0.63 1.8 LS/Vtec with Crower Turbo cams
450whp on pump gas sounds like a happy dyno !!
Old Aug 3, 2010 | 06:01 AM
DarKStaR5's Avatar
Why is this hard to believe?
I made 420whp on 18psi on a 81.5mm lsv on 93oct, but we had to stop there because i was having issues with it breaking up and couldnt figure it out. Which later on was found to be a crack in number 3 spark plug wire. I could have made 450whp easy.
Old Aug 3, 2010 | 06:38 AM
631 Teggy's Avatar
Not sure if this will help since it's not a built block but here goes.
98 GSR Stock (w/ the exception of ARP head studs & a fresh OE headgasket)
57 trim, Tubular manifold (peakboost), 3" downpipe & exhaust, 550cc inj, walbro in-tank 255lbh, Neptune by Jeff Evans, stock map sensor
It made 350-360whp at 10psi, and we detuned it to 325whp/245wtq @ 9psi
Here is an OLD video from the tune: http://www.youtube.com/watch?v=uCvGmEXcNnA
Old Aug 3, 2010 | 06:42 AM
i hink he said that because it's on pump gas what pistons and ratio did you have at 420 on 18psi
Old Aug 3, 2010 | 06:50 AM
non-VTEC's Avatar
i will add...my 440+whp dyno run was on 94oct pump gas (easily available around here) with a basic cooling mist water/meth injection system (50/50 mix) tuned on ectune. and it was tuned VERY conservative...ignition timing at the top end is @15deg or less.
http://www.youtube.com/watch?v=LyCKij30TIY
Old Aug 3, 2010 | 08:08 AM
killercivic87's Avatar
i have the same turbo Gsr motor at 22psi on dyno 429hp
Old Aug 3, 2010 | 08:11 AM
DarKStaR5's Avatar
i have wiseco flat tops(10:1)
Old Aug 3, 2010 | 08:50 AM
TheShodan's Avatar
Moderator
Using a meth water injection system is very doable. I'm looking at simply the fact that this was done on 93 octane gas ONLY, with no supplementary fuel systems. that means its being read high on the dyno.
Old Aug 3, 2010 | 08:51 AM
TheShodan's Avatar
Moderator
Please state the fuel that you used, as well as all supplementary fuel systems.
Old Aug 3, 2010 | 08:56 AM
DarKStaR5's Avatar
Right now im around the 370whp level on wastegate but im going back to turn it up hopefully in the next month or so, looking for a little over 450whp. All on 93 pump with single walbro and rc1000s.
The setup before where i made 420whp cracked a sleeve prematurely so i swapped everything over to a sleeved block(81.5mm)
Old Aug 3, 2010 | 08:59 AM
092eg6's Avatar
heres my new set-up for the street/daily driver and 1320 track, looking for 300-350whp
Head:
b16a3 head no port
b16a2 manifold polished runners
stock b16 tb
GSR cams/AEM cam gears
Supertech springs/retainers
gaskets:
honda oem head gasket
hondata intake manifold gasket
Block:
b20b stock bottomend
ARP head studs
Transmission:
stock gsr
Competition stage 5 clutch kit
oem flywheel
Turbo set-up:
304ss Ramhorn Turbo Manifold
Tial 38mm wastegate
3"Down Pipe
Garrett t3t4 57trim .60 compressor .48ar stage 3 turbine wheel
2.5" pipings/ ebay fmic
greddy type S bov
B&R oil line kit
Fuel:
Cali 91octane
Walbro 255 fuel pump
RC 750cc injecctors
engine management:
Chip PO6 ecu on Crome all day! (will switch over to hondata s200 if i find out that its got boost options)
GM 3 bar map sensor
Old Aug 3, 2010 | 10:46 AM
A1's Avatar
A1
its not a b16 but another 57trim setup i built.this time on my own car.running cali pumpgas on the street and erc purple on highboost.since its my car,ill be back at dyno as soon i receive my s300 and 1k injectors to push it's limits on 57trim .:-)
http://www.youtube.com/watch?v=-iuwP_E4Aps
Old Aug 3, 2010 | 11:15 AM
092eg6's Avatar
what was it tuned on ?
Old Aug 3, 2010 | 11:59 AM
civicjunkie17's Avatar
is there really alot of lag between 57 trim and 50 trim? im really stuck in between the two
spoolinvtec54
May 11, 2011 12:08 PM
SiKid86
Sep 14, 2006 08:57 AM
projectPSI
Nov 18, 2005 10:23 PM
BuBBa y0!
Oct 17, 2004 01:34 PM
riceburnah
Jul 14, 2004 08:02 PM
