D16z6 bubble not running right
Old Jul 25, 2010 | 07:27 PM
d16allday's Avatar
Default D16z6 bubble not running right
I have a d16z6 in a 93 civic hatch running a p28 ecu
Heres my issue
Anywhere below 3000rpms the car breaks up terribly, starting from a light is almost impossible full throttle. I tried doing the ignition timing tonight with a brand new distributor, with the distributor turned all way towards the back of the car, it idles great at 800+ rpms, but mashing the throttle in neutral makes it break up and pop. The car above 3k at WOT is fine and doesn't break up, but it DOES break up in all rpms at half throttle. Input? With the IGN timing all the way back, the 3 marks on the crank ALMOST line up with the timing marks
Old Jul 25, 2010 | 07:36 PM
92lxsleeper's Avatar
Default Re: D16z6 bubble not running right
sounds like the TPS is bad. check that first.
do you have a CEL? does your CEL even work?
Old Jul 25, 2010 | 07:39 PM
d16allday's Avatar
Yea CEL works, throwing P041 for 02 sensor heater circuit, was throwing a code for Vtec Pressure switch also, but that was just wiring issue
Old Jul 25, 2010 | 07:41 PM
builthatch's Avatar
MiG-21 superfan
Heres my issue
was the car running fine for a while and this just popped up? is this a freshly installed setup?
how do you have that code? thats an OBDII code and your car is obd I if you use the p28 ecu.
Old Jul 25, 2010 | 07:45 PM
d16allday's Avatar
Yea sorry i'm tired lol, both my other cars are obd2 i added p0 in by accident..... CODE 41 is what i'm throwing
Old Jul 25, 2010 | 07:46 PM
hondanube2010's Avatar
also its possiblly a broken reluctor wheel (crank or cam sensor) ignition (pip) signal. but it probably wouldnt run if u didnt have a good crank signal
Old Jul 25, 2010 | 07:49 PM
d16allday's Avatar
The car was ok for a while and one day at a light the car just shut off, turned it back on, hard to start, sounded like timing belt skipped teeth, wouldnt idle, ran terrible etc etc. So I started driving my other car and kept procrastinating on fixing this, buddy broke his car so Im letting him drive this to work, so it has to get fixed. He had the timing belt off last night and said the timing was a bit out, so he retimed it and the car ran fine for like 15 minutes, once it warmed up it started running terrible. We put a new distributor on because that was a previous issue and now were trying to time it, but the marks will not line up no matter how far back you turn the distributor.
Old Jul 25, 2010 | 07:52 PM
builthatch's Avatar
MiG-21 superfan
dude i would double check the static timing, the relationship between the camshaft and the crank.
cam sprocket up mark at 12 o'clock, lower belt cover pointer lined up with the lone mark on the crank pulley that is apart from the 3 together
Old Jul 25, 2010 | 07:54 PM
d16allday's Avatar
Buddy is saying everything lined up with the timing belt.
Old Jul 25, 2010 | 08:04 PM
Solster's Avatar
sounds like the TBelt is stretched and or he's off a tooth still. never seen a honda motor that far out of time with out that being an issues.
remember to turn the engine 720 Deg. after seting the tension and make sure the timing marks on the cam and crank are still in sync.
fully rotating the engine will pull ALL the slack out of the TBelt.
also did you remember to short out the diag connector when setting timeing???
also dose this engine have a adj. cam gear???
had one at work we diag'ed as a skiped tooth turned out all 6 bolts holing the cam gear where lose and it was jumping the timing around.
Old Jul 25, 2010 | 08:12 PM
d16allday's Avatar
Yeah they said they turned the motor and everything was still lining up. Yes we jumped the connector when setting the timing, its the same one you jump to read trouble codes, yes? Engine does not have an adj cam gear, stocky ocky.
builthatch's Avatar
MiG-21 superfan
x2
Old Jul 25, 2010 | 08:21 PM
Solster's Avatar
ok well the only thing i can think of then is Poor fulling injector stuck open or not opening all the way.
the D16Z6 motor only has the sensors in the dissy for controling spark. Nothing on the Crank.
and you replaced that so.
um MAYBE you have a craked Dissy cap that will make the car run All over the place also check plug GAP
***DING***
Just remembered ALL cars I have seen that run like that. all have E3 spark plugs There crap and i have seen More ppl spend $$$$.$$ putting in new sensors and other parts over a Set of E3 plugs.if it has them thorw them away. and get any thing ealse hell the old plugs from a lawn mower are better then E3
Link to the E3 Deamon plugs for referance.
http://www.e3sparkplugs.com/
Old Jul 25, 2010 | 08:32 PM
Former User's Avatar
sounds like the TBelt is...off a tooth still.
X3
Old Jul 25, 2010 | 09:07 PM
DCRB's Avatar
motor running on all four cylinders? good compression? my old motor ran like what you describe, it had almost no compression in one cylinder... i could pull off the plug wire on that cylinder and not notice a difference in idling
Old Aug 5, 2010 | 10:16 PM
Solster's Avatar
Is it just me or does it seem that ppl forget thay ever posted a question?
Old Aug 16, 2010 | 06:25 PM
d16allday's Avatar
Didn't forget i took everything into consideration
Old Aug 16, 2010 | 06:29 PM
builthatch's Avatar
MiG-21 superfan
AND...
Coupelife95
Aug 22, 2014 02:09 AM
civic_turbo_wannabe
Jun 6, 2009 01:40 PM
94VXLSHatchie
Jul 4, 2006 01:58 PM
HiProfile
Jul 23, 2005 08:38 AM
DecrazedBryant
Jul 1, 2005 09:50 PM
