Automatic wavers when switching gears
Old Jul 24, 2010 | 05:02 PM
rugimpy's Avatar
Default Automatic wavers when switching gears
I am working on a friends 96 civic ex and they are having a problem. First off, it is an automatic. When I drive it on the freeway and it switches gears, it feels like the car kind of waivers, or like rocks back and forth. I dont know how to explain it. It still shifts to the next gear fine but it seems like it bogs or waivers when switching. Any thoughts? Thanks!
Old Jul 25, 2010 | 07:24 AM
rugimpy's Avatar
Default Re: Automatic wavers when switching gears
Anyone?
Old Jul 25, 2010 | 07:58 AM
Former User's Avatar
Any CEL codes? Have you tried 2X draining the ATF and refilling with Honda or Honda-recommended ATF?
Old Jul 25, 2010 | 08:59 AM
rugimpy's Avatar
No CEL codes. Havent tried redoing the ATF cause she said she just had it done. That would be my next guess though. Anything else?
Old Jul 25, 2010 | 09:10 AM
talonboy1991's Avatar
I'm not sure what it could be but every automatic trans honda I've ever driven or rode in has shifted goofy? Mine shifted really hard and I was told by the previous owner that it was just flushed and that it had done it since he had got it at 80k and it was still working good til 218k when I took it out to swap for a 5speed
Old Jul 25, 2010 | 09:13 AM
Does the CEL work? Or did you check for codes using a code reader?
Old Jul 25, 2010 | 10:25 AM
95civtecex's Avatar
My auto trans still works great with 205k on it, but at slower speeds like when you come to a light an almost stop but it turns green so when you put your foot back on the gas it feels like it's between gears then slams into first I thought this was odd cause every auto I've owned/driven never did this
Have you checked any of the motor/trans mounts? Maybe that's your problem an if not you can rule it out
Old Jul 25, 2010 | 08:03 PM
rugimpy's Avatar
I dont think it is a physical thing like a bad mount if that makes sense. I feel like its something internal, either tranny or fuel or spark. Any more thoughts?
chevydad8
Mar 21, 2016 06:56 PM
74baja
Honda CR-V & Element
Nov 30, 2014 11:18 AM
itsnotfast
12
Aug 17, 2011 07:52 PM
verbol assassin
Oct 17, 2005 08:22 PM
