LS/Vtec vs PoorMan's Type R
Old Jul 14, 2010 | 11:21 AM
JPerkMr954's Avatar
Default LS/Vtec vs PoorMan's Type R
I have been doing a lot of reading for the past few days into the poorman's type r and I'm interested in it. I then began to see that people strayed away from this setup to go ls/vtec because there are kits available now and it has become more reliable of a setup then in earlier years. I myself am looking for reliability and dependability over all but I do want power as this is my daily driver but I am looking for a good platform to start with that later If I so choose I can do more.
Are these 2 indeed the same and if not what are the differences?
Old Jul 14, 2010 | 11:49 AM
B16AGUY's Avatar
Default Re: LS/Vtec vs PoorMan's Type R
If I'm not mistaken they are pretty close... the Poor man's type R is pretty much a:
B18 Block
Vtec Head (B16, B18C, or even a type R head if you can find one)
Type R Cams
I believe you'll need a an ECU as well... I saw on another site that someone was using a P73 and P73 Pistons but I have no clue if those are necessary as I am by no means a motor pro.
The LS/VTEC is basically an LS block (i.e. B18B) with a Vtec head (B16A is most popular choice)
Old Jul 14, 2010 | 11:50 AM
Deetz's Avatar
Crazy Honda Guy
They are NOT the same! Although LS and B20Vtec swaps are popular because they are cheap, a true vtec block still has the advantages.....
by using a true vtec block
- Has the proper oil passages for the vtec head
- "better" reliability for head gasket sealing in the long term
- the mains for the crank are better designed for strength
I am not bashing LSvtec, it's just that a B18C block is the better option out of the two
Old Jul 14, 2010 | 02:31 PM
REDEM1FTW's Avatar
Icon2 Re: LS/Vtec vs PoorMan's Type R
I don't understand what would make a poor mans r more apealing than a gsr besides I guess a little higher compression? Is the power difference between the two THAT significant?
Old Jul 14, 2010 | 03:01 PM
RCurioso88's Avatar
man, for the longest time I thought a poor man's Type R is LSVTEC. What's the difference? As for LSVTEC, i've had 2 and I love it! Sure there's a lot of horror stories about them but mine is as reliable as any Honda motor i've owned. If you build them right, they are a lot of fun.
Old Jul 14, 2010 | 03:18 PM
-__-'s Avatar
poor man's type-r is basically a type-r engine when done CORRECTLY. slapping a B16 head on a stock GSR will give u LESS compression. LS/VTEC: B18B/B18A block with a VTEC head. Poor man's type-r: B18C GSR block fitted with type-r pistons, cams, valvetrain, intake manifld and throttle body. thus making it for the most part a type-r engine.
*also the B-series VTEC motors have oil squirters on the block to coat the cylinders. LS do not.
Old Jul 14, 2010 | 03:44 PM
Deetz's Avatar
Crazy Honda Guy
Do you know what a poor man's type R is? I never said anything about one being better than another.
A poor mans type R is a B18C block with PR3 head (B16)
A GSR is a B18C block with P72 head (gsr)
They are pretty much the same thing!!!!
An LS vtec is a NON vtec block with either vtec head bolted to it!!
Old Jul 14, 2010 | 03:47 PM
-__-'s Avatar
^^bingo.
Old Jul 14, 2010 | 03:53 PM
94_DC's Avatar
This is true, the term "Poor Mans R" came from the b16 head being very similar to the Type R head, only difference being a port and polish and some better valve train.
As said before b16 head LOWERS compression.
The reason for LS/Vtec is for more torque and depending on which head more compression.
Old Jul 14, 2010 | 04:10 PM
GranDaddyPurp's Avatar
if the b16 head lowers the compression on poor mans r, then the pmr would be more ideal for a mild turbo setup correct.
i prefer the ls/vtec when done correctly. my ls/vtec is done right and i have no complaints the horror stories i hear about are more like myths to me.
ls/b20 vtec is awesome
Old Jul 14, 2010 | 04:44 PM
RCurioso88's Avatar
Same here man. I love my LSVTEC cuz I did it right and pretty much built it to be bullet-proof lol
Old Jul 16, 2010 | 05:37 AM
B16AGUY's Avatar
If you look at it like that then yes but bear in mind that as others stated a TRUE poor man's R would have the pistons, cams, valvetrain, intake mani etc... swapped with type r ones, so that would bring back up the compression.
Could someone chime in on this as I honestly know very little about this setup so I might be wrong.
Old Jul 16, 2010 | 06:12 AM
tommybdelsol's Avatar
So I have a 94 del sol and i was thinking of building my d16 but what is this talk of a "poor mans" type R. What does it cost, about to do one of these?
Old Jul 16, 2010 | 06:33 AM
98y8's Avatar
Like stated above, poor man's type R is a GSR block, with type r pistons with a b16 head with type r valvetrain.
Old Jul 16, 2010 | 07:42 AM
I know what it is i was just wondering about how much it costs.
Old Jul 16, 2010 | 09:27 AM
D Griff's Avatar
It just all depends on where you source all your parts, if you do work yourself, etc. But it would probably cost at least as much as doing a straight GSR swap, probably more.
Old Jul 16, 2010 | 10:20 AM
Deetz's Avatar
Crazy Honda Guy
Just to add to that, there is hardly a difference....we are talking 0.1 compression difference, that's it. This could be compensated from just a thinner head gasket
Old Jul 16, 2010 | 12:02 PM
Ok cool thanks for your help guys
JDMeman
Mar 21, 2008 02:53 PM
latinf86
24
Nov 29, 2006 07:35 AM
KMk51188
May 31, 2006 02:54 PM
99lsvtecauto
Nov 16, 2003 03:09 PM
eg_nezay
46
Dec 23, 2001 06:58 AM
