help with b16a2!
Old 07-06-2010, 10:29 PM
erichackett's Avatar
Icon3 help with b16a2!
ok so heres the deal. recently had a b18 block attached to my original b16a2 head. i decided to get the original b16 block and swap it back in.
the car ran pretty good before hand and after 3 weeks of work (mostly waiting for miscelanios parts to arrive) i got it all set back up.
i went to crank it today and it idles horribly! and if i step on the gas at all it dies at about 3000 rpm. i went back and checked all my hoses and sensors but everything looked right.. i have no leaks (that i can see).
it is also putting out alot of smoke from running to rich. i have some msd injectors in it and i was running rich before but now it seems i am running extremely rich because ive got a ton of black smoke comming through the exaughst. also after about 30 seconds of it running my new spark plugs were coated in soot.
i checked the timing and it seems to me to be pretty dead on. i had even hand turned it over several times to make sure there was no resistance.
any sujjustions would be great!
Old 07-06-2010, 10:38 PM
-__-'s Avatar
Default Re: help with b16a2!
what kind of ECU are u running? also obd-1 or obd-2? try replacing the injectors with stock ones first. eliminate varables by using OEM parts :D
Old 07-06-2010, 10:48 PM
yeah the first thing i tried was stock injectors... im running a obd1 ecu with a jumper harness. its a p05 and chipped to work with the b16a2. it ran fine before i took it apart.. i have done a compression test which came back fine and i tripple checked my camshaft timming.
Old 07-07-2010, 05:23 AM
Retired Moderator
EsotericImage's Avatar
Soo, your ECU was tuned for the 1.8l and now your using the 1.6 liter. Have you gotten re-tuned for the new block?
Old 07-07-2010, 08:03 AM
no i hadnt. i actually ordered the stock em1 ecu. will this fix the problem? would the tune for a 1.8 really affect it like that?
Old 07-07-2010, 11:43 AM
Retired Moderator
yea man, thats why your running rich, either get a new tune (i recommend) or buy a new ECU.
Old 07-07-2010, 11:56 AM
OneQuickEM1's Avatar
Oh dear......
Old 07-07-2010, 12:17 PM
Retired Moderator
Oh yea.. since your using larger injectors, your definitely flooding the engine with gas. Re-tune with these injectors cuz a stock ecu will help, but only with stock injectors.
Ef8crxsi4u2nv
03-13-2011 02:49 PM
shwanC
11-18-2010 11:09 AM
CivSiClone_96
09-14-2009 09:59 PM
SimplyTron
01-20-2006 10:20 PM
Quick Reply: help with b16a2!
