Gears grinding when shifting at high rpm's?
everytime i shift into third at any rpm above 6 grand, i get a grind like i cant shift.
does any body know what the hell it sould be from: new syncros, etc...
thanks
josh
ps. this is my first post on this or any import board so just want to say hello too. I've just switched from the domestics to my first import. was just too tired of geting 10 miles to the gallon.
VIVA MEXICO!!
thanks
josh
VIVA MEXICO!!
99% sure its syncros.
And welcome to the boards
EDIT: Welcome to the Honda 3rd gear grinding club!
[Modified by 92TypeR, 1:33 AM 9/15/2002]
does anyone know that it runs on these cars to have fixed.
oh and 92 typer, ill take a dos XX thanks you, not the amber either dammit.
my buddy has a tyype r and the same thing happens only in third. he had synchros fixed.,.. nothing.. third gear changed...nothing. it is a 2000 and still to this day it still grinds. he is afraid to take it to anywhere else than acura b/c might void 7 year warrenty. already went through 3 third gears. i would also like to hear of any suggestions
I have a 2001 ITR and the fvcker always grinds into third. I have had it fixed by the dearlership and the dam thing still grinds. I would say try putting some GM syncro mesh in it maybe that will help.
make sure you're depressing the clutch pedal all the way to the floor when shifting... that might help.
also, like someone else mentioned, try changing your tranmission fluid. Honda MTF should be fine.
