how to test LSD
Old Sep 14, 2002 | 01:45 PM
johnzm's Avatar
Default how to test LSD
i went around a corner today and got massive wheelspin on the inside tire. how can i test my lsd out to make sure its still good?
Old Sep 14, 2002 | 01:48 PM
92TypeR's Avatar
FSAE
Default Re: how to test LSD (johnzm)
Jack up the car.
Make sure both front wheels are off the ground.
Put the car in 1st.
Turn one of the wheels, the other wheel should rotate in the opposite direction.
If that doesn't happen, you have a turded out LSD.
Old Sep 14, 2002 | 02:11 PM
johnzm's Avatar
Default Re: how to test LSD (92TypeR)
Jack up the car.
Put the car in 1st.
wel they rotated in oppisite directions. with alot of resistance. is that normal?
Old Sep 14, 2002 | 02:15 PM
BDiddy's Avatar
Do a burnout and see how many strips of rubber you have left
Old Sep 14, 2002 | 02:27 PM
johnzm's Avatar
Default Re: how to test LSD (BDiddy)
i cant i have a new clutch and new flywheel in it
Old Sep 14, 2002 | 02:46 PM
92TypeR's Avatar
FSAE
Resistance? As in it took A LOT of force to turn the wheels? There should be about a 1/2 inch of 'free play' when turning the wheels, then the other wheel should turn.
Old Sep 14, 2002 | 02:57 PM
johnzm's Avatar
it has the 1/2 inch of free play, so i guess im good
Old Sep 14, 2002 | 04:32 PM
johnzm's Avatar
hey guys, i just had a friend look while i took a corner, i had alot of wheelspin on the inside wheel and he told the the outide wheel wasnt spinning. this isint a common thing with a LSD trans is it?
Old Sep 14, 2002 | 04:34 PM
Dr Pooface's Avatar
The inside wheel shouldn't spin.
Old Sep 14, 2002 | 04:36 PM
D's Avatar
D
how to test LSD
put tab on tounge, wait a hour or so.
[Modified by D, 8:36 PM 9/14/2002]
Old Sep 14, 2002 | 04:37 PM
sackdz's Avatar
Default Re: how to test LSD (D)
how to test LSD
LOL
Old Sep 14, 2002 | 04:48 PM
johnzm's Avatar
Default Re: how to test LSD (Ddub)
so ummmmmmmm it worked alright on tha test i was told to do., what else can be done to test it?
Old Sep 14, 2002 | 05:25 PM
Dr Pooface's Avatar
Lift up the front end.
1) put the car in first and measure how much torque it takes to spin the wheel
2) put it in neutral and do the same.
if 1 divided by 2 is greater than 2.25 you have a problem.
Old Sep 14, 2002 | 07:06 PM
Tommy_Gunns's Avatar
Wow, I never heard of this, where did you get this from?
BTW - to the person who said do a burnout, that doesn't work. Cars without LSD can do 2 wheels burnouts as well.
Best method I know of: put one side on grippy surface, other side on slippery surface, 1/2 throttle, if you get massive wheel spin on the slippery side, you got a problem.
[Modified by Tommy_Gunns, 10:08 PM 9/14/2002]
Old Sep 14, 2002 | 07:11 PM
BDiddy's Avatar
Default Re: how to test LSD (Tommy_Gunns)
More times than not it works. especially if he knows he has LSD and needs to test it. If it was broken I dont think it would work. And besides. IT WAS A JOKE!!!!
NashDishesDimes
18
Oct 20, 2010 08:15 PM
3vilMonkey!
May 17, 2005 03:26 AM
kb58
11
Mar 19, 2005 07:12 AM
charjacq
11
Mar 21, 2003 07:54 PM
johnzm
Sep 14, 2002 02:48 PM
