Quick question about taking off power sterring components.
Old Jun 29, 2010 | 09:15 PM
Andrew14's Avatar
Default Quick question about taking off power sterring components.
Ok, so i have a 93 civic with power sterring and i want to take off the power sterring but not damage my rack and pinion. So could i just take off the pump, with the belt and bracket, hide the p.s. line under the car. Also, could i just leave fluid with in the p.s. lines and cover the two lines that were connected to the pump with a two open ended hose. A hose that you would use on your radiator to the reservoir. If i do this i will not have to worry about my rack and pinion getting messed up.
Old Jun 29, 2010 | 09:53 PM
98civdx's Avatar
Master Detailer
Default Re: Quick question about taking off power sterring components.
Take the lines off, and just get one and loop it.
Old Jun 29, 2010 | 10:02 PM
Andrew14's Avatar
yea thats kinda what i did. i didn't remove the hard lines on the body of the car, so i used a two open end hose poured power steering fluid into the bottom line, so the rack is still greased and closed it up by putting the other open end of the hose on the top line.
Old Jun 29, 2010 | 10:04 PM
98civdx's Avatar
Master Detailer
Eh, i would remove the line entirly, they are ugly.
But it's your car.
Old Jun 29, 2010 | 10:13 PM
Andrew14's Avatar
but if i do this it will not mess up my rack and pinion. Also is there anywhere i can put my p.s. line but besides under the car.
Old Jun 30, 2010 | 12:08 PM
98civdx's Avatar
Master Detailer
No, you will be doing the same thing as you did, only removing the factory lines and adding your own.
Again remove the factory lines, and you wont need to hide anything.
rnacion
Mar 24, 2014 08:47 AM
nota-eg
11
Aug 11, 2005 08:06 PM
Hockey27925
Mar 25, 2005 10:38 AM
3.504
Mar 8, 2004 09:00 AM
norice
Dec 4, 2001 09:26 AM
