axel seal replacment
Old Jun 29, 2010 | 01:42 PM
harms_is_back's Avatar
Icon2 axel seal replacment
i need input and help im about to do this tomorrow i need pictures if you have them or instructions on how to do it as im gonna be changing both seals of the tranny as it will be removed out of the car so i can make sure im doing it right. the seals that im replacing is off a type r LSD 4.4 tranny please i just want to make sure im gonna do it right thank you in advance.
Old Jun 29, 2010 | 01:51 PM
BlueIntegraBoy's Avatar
Default Re: axel seal replacment
I had to do mine while the tranny was still in the car. PITA.
Make sure you put the right seals on the correct side, since they are different sizes. Basically you pull out the seals (a flathead used to pry it out, but make sure not to scratch the inside). Grease (with tranny fluid) the outer part of the seal before you put them back. You can use a mallet to tap it in. Oh, don't damage the inner spring (tensioner spring) during the install. It's straightforward.
Old Jun 29, 2010 | 01:58 PM
alright cool yea i been thru three type r trannys lol caseings kept blowing up on me lol any ways this one has been lasting so want to do it right
Old Jun 29, 2010 | 06:01 PM
bump any other input hell anyone have pic's of it? lol
Old Jul 2, 2010 | 01:58 PM
ok im doing it right now. so just pull it out with a flat head does any one have pictuers of what a busted one looks like?
Old Jul 2, 2010 | 04:17 PM
The inner tensioner spring was all mangled on mine. So, if tension isn't even there will be a leak. Must be from previous owner when he reinstalled axle.
soon2beB00stedSOL
Oct 19, 2006 07:40 AM
Jer'rome
Oct 1, 2004 09:54 AM
ECKOTYPER
Apr 9, 2004 08:26 PM
eg6h8k
Jun 21, 2003 12:30 PM
HondaCutter
Dec 27, 2002 02:32 PM
