bad axel or tranny?
bad axel or tranny?
i have a oil leak by the passenger side axel. i jack up the car to find that the part where the axel goes into the tranny is loose!! it moves up and down like its not in fully but it is!?!?! it it my tranny, axel seal or the tranny??
Re: bad axel or tranny? (low'N'slo)
the part that the axel goes into the tranny? its probaly just a seal nothing can be loose at that spot you may be able to wiggle the case a little like within a 1/16 of an inch. if the metal case on the axel is not flush on the tranny then i would say that your differential busted
mine done the same until a piece of metal got jammed up and then snapped of the outer edge of the case but that was where the jack shaft was
Re: bad axel or tranny? (aziz93)
Replace the seal, it's like $5, and examine the axel while it is out. Their should be a locking "c" clip on the end of it to hold it snug.
BattleEK
14
09-17-2018 09:25 PM
