dizzy placed in 180 out..
Old Jun 26, 2010 | 10:47 AM
jah.tien's Avatar
Default dizzy placed in 180 out..
does it cause damage?
i pulled dizzy to change rotor...
now it starts, barely, and dies...unless i give it gas..
Old Jun 26, 2010 | 11:07 AM
InvaderTrax's Avatar
Default Re: dizzy placed in 180 out..
So you flipped it and now it won't run properly?
Old Jun 26, 2010 | 12:30 PM
Duane_in_Japan's Avatar
Putting it in the wrong way has been known to break off one of the drive tabs but it sounds like yours is ok, you have a different problem, not saying its not in the dizzy though, there are cheap caps and rotors that dont work well, that goes for non NGK spark plugs too, same with cheap wires, could be many things.
Clean the IAC and the entire throttlebody too.
Old Jun 26, 2010 | 12:34 PM
jlude90's Avatar
Yeah, you really can't put them in 180 out. Honda is smart, and knows that techs are stupid. They made it unpossible to screw it up too much.
Might just be out of time.
Old Jun 26, 2010 | 01:30 PM
darkestfenix's Avatar
x2..... you cant put it any way but the right way. Its 100% dummy proof.
The only thing i can think of (since i dont understand what your trying to say)..... is did you fully remove the distributor to replace the rotor?
If yes:
1) Why in gods name would you do that?
2) If you didnt screw the distributor back in at the EXACT same place, then your ignition timing is off.
If no: disregard what I wrote.
Old Jun 27, 2010 | 07:44 AM
Edul59's Avatar
isnt there a slot on the dizzy that prevents incorrect installation, so it could and has to be something else
Old Jun 27, 2010 | 09:13 AM
If yes:
Considering he hasn't specified a year, he may have one of the old distributors. I worked on an '89, and although the distributor itself can't be installed 180 out, the rotor can
Old Jun 27, 2010 | 09:37 AM
jah.tien's Avatar
k folks, this is what happend...
YES dizzy DID go in 180 out. NO LIE.
2. I DIDNT TIGHTEN THE SCREW ON ROTOR TIGHT ENOUGh, THTS what he problme was.
and C. i had to take dizzy out bcause of problems with rotor screw, it was stripped..so had to get whole contraption out so i can get screw out.
Old Jun 27, 2010 | 12:54 PM
jlude90's Avatar
what year? I've watched people hammer their distributors trying to get them in because they were 180 out.
Old Jun 27, 2010 | 03:19 PM
jah.tien's Avatar
h23 blue top...
i didnt hammer it in..just went it..
n e way...all that is fine...
but my problem now is
car dies at idle but runs great...
when im mving and shifting...great...
but soon as i stop...or turn on ac at idle...dead..
Old Jun 27, 2010 | 03:23 PM
jah.tien's Avatar
Old Jun 27, 2010 | 07:51 PM
There are posts of folks stating that the dizzy can go in 180 out, I have even seen it myself, yes, you have to push hard, people do it, and they dont break.
Old Jun 27, 2010 | 09:41 PM
Is the ignition timing adjustable? And is this the first time it's been started since it was swapped? There are plenty of reasons why it won't idle, especially if you just now got the whole swap running
Old Jun 28, 2010 | 06:49 AM
jah.tien's Avatar
engine has been running fine for the longest time...
all thats happened is i changed dizzy rotor...and now it dies at idle...
i swear thats all i touched.
even know when i drive it down the street, runs great...but when it gets back to idle...dies..
Old Jun 28, 2010 | 09:06 AM
Enzo15's Avatar
Could it now be a problem with either the IAC or the Idle screw? O but you said it was fine before. Nevermind
Old Jun 28, 2010 | 11:00 AM
jah.tien's Avatar
yip. every thing was running top notch...slight burps..but thats because i know i need a tune...nothing too noticeable. and again, even now, i car drive the car and u cant even TELL the car dies at idle...everything is still smooth.
DailyGrinderEJ8
Oct 3, 2014 06:14 PM
efyou
Jul 28, 2006 03:50 PM
itslogics
Jun 19, 2006 04:36 PM
mjrage
May 31, 2004 09:48 PM
W.O.P.
May 1, 2004 06:54 AM
