give it gas and it dies!!!
Old Jun 19, 2010 | 10:25 PM
608_red_rex's Avatar
Default give it gas and it dies!!!
I have a 93 civic dx hatch and we just changed the head gasket. I drove it around town a couple of times, but now when I go to start it, it starts out great, but anytime that I give it gas it dies on me. I have switched the dizzy, i have checked the cat thinking it might of been clogged, but nothing. The car is completely stock. Any help would be great guys.
Old Jun 20, 2010 | 05:44 AM
rndy444's Avatar
Default Re: give it gas and it dies!!!
check the carb.
Old Jun 20, 2010 | 06:05 AM
gibsanez's Avatar
Originally Posted by rndy444
check the carb.
Seriously?
OP, do you have a check engine light?
Old Jun 20, 2010 | 07:58 AM
owneyboy's Avatar
lol is right. maybe your grounding out a wire orsomething to make it run stupid
Old Jun 20, 2010 | 08:48 AM
delsolo95's Avatar
check the grounds. especially on the thermostat
Old Jun 20, 2010 | 07:50 PM
Originally Posted by gibsanez
Seriously?
no check engine lights at all.. do you really think it could be a ground? b/c after the head gasket change out it drove fine for about 3 days then it started to do this..
Old Jun 20, 2010 | 07:56 PM
HAMOTORSPORTS's Avatar
tps unplugged/ loose
Old Jun 20, 2010 | 08:01 PM
Nbboy7's Avatar
Check the timming.
Old Jun 20, 2010 | 08:05 PM
92bseries's Avatar
if it was a ground wire the car wouldnt have started AT ALL, like boy an motorsports said, its either out of time, or the tps isnt in the original position it was b4 u did the work. i had the same problem with my b16 while back and it was the damn tps
Old Jun 20, 2010 | 09:34 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You might have swapped the TPS and MAP plugs. Or you may have swapped some other plugs. Honda uses a lot of the same shape plugs in the same area for different sensors/outputs.
The TPS and MAP plugs will plug into each other. So check that.
Also, check that the car is getting enough fuel. Unplug the FPR vacuum line to make it run stupid rich and see if that helps. You may have put the fuel rail feed line on incorrectly.
Old Jun 20, 2010 | 10:30 PM
the TPS plug is in tight, I will have to check to see if I swapped those two plugs around. The timing is on ( used a timing gun) and it is gettin fuel, b/c when I turn on the car it idles fine. Just when I step on the gas then iT dies. I will go and try to switch the TPS and MAP plugs see what happens. The worst is that it wont start at all right?
Old Jun 20, 2010 | 10:40 PM
92bseries's Avatar
it will start either way, jus wont drive if it has the wrong plugs plugged up, just remember.........if ur switchin the plugs u have to reset the ecu so its reads everything the right way otherwise it will still read the cel code
Old Jun 21, 2010 | 04:43 PM
quapouh's Avatar
MAP sensor or a ground (car will start with 2 grounds unplugged but it will die with a hint of load) checked empirically
Unplug MAP sensor and see if it makes any difference (you will get a code so be prepared) if it doesn't make a difference it is more than likely your MAP (source known working MAP of your buddy and test again)
raider1qaz
Feb 5, 2013 05:49 AM
DcLs
Apr 1, 2009 09:53 PM
Phrost
46
Sep 3, 2006 10:47 PM
insomniac791
Aug 15, 2005 02:00 PM
01LSTeggy
Feb 16, 2003 11:42 AM
