s300 Boost Controller MAC install help?
I have searched and no luck on a visual.
I have my controller wired up and ready, I just want a pic of someones installed with the vaccum lines.
MAC solenoid is labeled, 1=manifold? 2=top of wastegate? 3=filter or left open?
Thanks for the help
Thanks for the help
1 goes into vacuum and the side of the wastegate. Just imagine if you had a vacuum line ran into the side of the wastegate to the intake manifold. You'd be basically tee'ing port 1 into that line.
2 goes directly to the top of the gate.
3 stays open and usually has some kind of filter/ open fitting on it.
here a good diagram:
http://tunertools.com/prodimages/AEM...st_30-4350.pdf
everything is done properly. just strt out by doing duty cycle only and go up a little at a time and recored how much duty is equal to what boost pressure. then input it into the graph below so you can do boost by gear which is great. helps out a ton with traction in lower gears
gofastjdmcivic
Apr 28, 2004 04:29 AM
psicrxsi
Oct 2, 2001 04:22 PM
