How to install a turboxs boost controller on tial 38mm wastegate? HELP
I just wanted to know where do I put the manual boost controller , on the bottom nipple or the top nipple of the tial wastegate?
Modified by gofastjdmcivic at 5:18 AM 2/27/2004
Re: How to install a turboxs boost controller on tial 38mm wastegate? HELP (gofastjdmcivic)
Use the side port of the wastegate and run a vaccum line from there to the bottom of the boost controller. Then run a line from the top of the boost controller to a intake manifold source.
Re: How to install a turboxs boost controller on tial 38mm wastegate? HELP (sneakypete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete »</TD></TR><TR><TD CLASS="quote">Use the side port of the wastegate and run a vaccum line from there to the bottom of the boost controller. Then run a line from the top of the boost controller to a intake manifold source. </TD></TR></TABLE> thanks for the info but I got it. all you have to do it hook it up inline from the compressor to the bottom of the wastegate.
Re: How to install a turboxs boost controller on tial 38mm wastegate? HELP (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">wow you draw amazering dax!</TD></TR></TABLE>
It's from TiAL's website. They send that drawing with their wastegates also. Don't give credit where credit isn't due.
Re: How to install a turboxs boost controller on tial 38mm wastegate? HELP (DaX)
yes its back from the dead.... but why do you have to hook-up that line before the Throttlebody????
I'm sure TiAL has a reason for this...but the only one I can think of is so the wastegate does not see vacuum. I have heard of people running this line from post throttle plate positions, but I'm following TiAL's guidelines. There must be a reason, and they know more about making gates than I do.
1baddturbosi
12-10-2006 08:12 AM
psicrxsi
10-02-2001 04:22 PM
