CIVIC TROUBLE>>>HELP PLZ
I HAD A CHECKLIGHT WHICH SAID I HAD A BAD THROTTLE BODY SENSOR... I CHANGED THE TPS SENSOR AND FOLLOWED THE INSTRUCTIONS TO SET IT BACK TO .45VDC.....MY CHECKLIGHT WAS CLEARED WILL ALEAST I THOUGHT SO UNTIL IT CAME BAC UP AFTER 15MINS OF IDLING.....THE CHECKLIGHT NOW READS I HAV A BAD VSS SPEED SENSOR........BUT MY RPM AND SPEEDO GUAGES WORK FINE.......DO ANYONE KNOW WHAT IS GOING ON
WOULD YOU MIND NOT TALKING ALL IN CAPS BECAUSE THATS LIKE SCREAMING ON THE INTERNET? ALSO YOU ARE NOT SUPPOSED TO LABEL TOPICS "HELP" AS IT DOES NOT DESCRIBE THE TOPIC. SOMETHING MORE APPROPRIATE WOULD BE "CEL AFTER NEW TPS SENSOR REPLACEMENT CODE#X"
Now that we got that out of the way make sure your engine is grounded correctly. Also check the VSS plug for any abnormalities such as exposed wires or something that should not be there.
gsr x civic
22
Mar 7, 2007 05:51 PM
igone916
Mar 3, 2003 08:59 PM
