code 17. . . vehicle speed sensor!
help!
i'm throwing this code and my speedometer isn't working. it'll sometimes surge and then die again. it has been broken ever since i was having fun in the snow (ff drift ftl, lol)
where exactly is the sensor? i know it's by the front tires / trans, but can someone pinpoint it out exactly where it is ?
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">on the tranny...right under the throttle body....someone here gots a pic ?</TD></TR></TABLE>
no need....just look at the tranny...its the only senson on the back of the tranny right below the throttle body..
right below the throttle body? do i need to get under the car ? or can i just look under the TB and it'll be there? how far is it under the TB exactly? lol. sorry. i mean it started happening when i was ff drifting . . . soo maybe it's just a loose wire?
Re: (gsr x civic)
you'll see it on top...if you look at the bottom of the tranny from under the car, you wont find it...its right below it...you can miss it...
Re: (gsr x civic)
yup its the only sensor there, held on by 1 10mm bolt.
here is wha ti would do, before replacing the VSS
take it apart (two 10mm bolts) clean that gunk out of it. regrease it and test.
thats what fixed mine.
Re: (gsr x civic)
click on here:
https://honda-tech.com/zerothread?id=382416
the 28th picture down shows what it looks like. sorry this was the closest link i can find and though it's on a b-series, the d-series should look the same or similar.
Re: (gsr x civic)
It looks like this out of the car.
http://www.flickr.com/photos/philwalter/413998982/
In the car it has three wires going to it, and is on the top back of the transmission. You don't need to get under the car to get to it, you probably need to take your intake off, but I don't remember. When mine went bad the sensor was actually fine, but the connection where the harness plugs into the vss was bad, so I just replaced the plug on it.
hey i saw that, but i didn't know that's what it was. someone said there was only 1 bolt. btw, what do you guys mean to regrease it when i'm putting it in? where do i regrease it? on the little gear thing?
Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic »</TD></TR><TR><TD CLASS="quote">hey i saw that, but i didn't know that's what it was. someone said there was only 1 bolt. btw, what do you guys mean to regrease it when i'm putting it in? where do i regrease it? on the little gear thing? </TD></TR></TABLE>
there is one bolt, well 3 total, 2 go to the bracket and the other one bolts the bracket to the tranny. but to remove it you just need to remove the one bolt from the tranny.
Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic »</TD></TR><TR><TD CLASS="quote">oh and also, why is that guy putting trans fluid in the hole where the vss came from? </TD></TR></TABLE>
thats where u put the tranny fluid threw..
LOL.
god i should have known. wowowow. i dont know why i'm being such a nub.
thanks a lot for your guys' help! i'm about to light up a cig and work on it, and i'll let you guys know what's up.
thanks again for the quick responses!
Re: (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">
thats where u put the tranny fluid threw..</TD></TR></TABLE>
technically, no you don't. there is a drain and fill plug on the tranny, which are beside each other.
can you fill the tranny with fluid through there? yes.
is it easier? yes
but seeing that the op is a noob to this kind of stuff, he should use the proper technics to fill his tranny and know when there is enough fluid.
is it easier? yes
hey guys. i got it out ! wooh!
anyway, when regreasing the gears, do you guys know if i can use grade 2 lithium grease to regrease it ? it's by valvoline and it's "multipurpose ep grease"
lmk asap, as the vss is sitting out of the trans. oh and btw, there was no gunk on it, so idk why i was throwing the code. . . ?
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
is it easier? yes
but seeing that the op is a noob to this kind of stuff, he should use the proper technics to fill his tranny and know when there is enough fluid. </TD></TR></TABLE>
yea...i knw proper way that is done, like you said...i rather go the easier route...and the noob should go the easier route as well or else it prob take him about a week to do it the "correct" way....in the end, its still the same sht..
is it easier? yes
Re: (B18CivicEH2)
yea...i knw proper way that is done, like you said...i rather go the easier route...and the noob should go the easier route as well or else it prob take him about a week to do it the "correct" way....in the end, its still the same sht..</TD></TR></TABLE>
yo man do you have to be so blunt? lol.
thanks for the help. i got everything up and running! thanks a lot for the help guys !
Re: (gsr x civic)
thanks for the help. i got everything up and running! thanks a lot for the help guys ! </TD></TR></TABLE>
i didnt mean it in a harsh way....sorry if you got butt hurt about it...
people tend to get all mad when called noob because they think its something really offensive even though it isnt...noob = new-b...somone new to the game.in your case, your a noob when it comes to troubleshooting and figuring out small things..
hotxcivic92
01-10-2008 12:48 PM
