hope to maybe get to 450whp..you think?
Old May 24, 2010 | 03:08 PM
DrivinVtec's Avatar
Default hope to maybe get to 450whp..you think?
heres my setup..i made 353whp at 18psi on pump gas.
wiseco 8.5.1
eagle rods
cleavite bearings
750cc injectors
STR fuel rail
ACT 6 puck cluth unsprung
lighten factory flywheel
removed balancers
energy Motor mount incerts.
walbro 255
arp everything (bottom end)
Garret t3/t4 60 63
tial WG
custom everything else (2.5 ic ,3in dp, log mani)
3" Exhaust
mustang Innercooler
Honda s100
I was told my exhaust was the culprit for such low power on that boost level. so this is what i did:
before:
after:
also buying a straight threw muffler. I also am purchasing a meth kit from coolingmist. my goal is around 450whp. does it seem possible?
Thanks
Old May 24, 2010 | 06:01 PM
DrivinVtec's Avatar
Default Re: hope to maybe get to 450whp..you think?
up
Old May 24, 2010 | 06:44 PM
Hawjap1gsr's Avatar
everything looks good. but number does seem low for boost. try a s300. is the head built at all?
Old May 24, 2010 | 06:47 PM
kyden's Avatar
your log manifold is killing power.
Old May 24, 2010 | 06:49 PM
dantamparacer's Avatar
you also need to look at the compression... the tune could be "conservative" also not much timing running a little rich. Also do you have e85 in your area? that might help a little but if you run it, you might need bigger injectors, sorry to lazy to do the math right now been a long day
Old May 24, 2010 | 06:51 PM
log manifolds can make power...I saw a gsr make 470ish corrected(i'm at 6k feet ele) with a log manifold. but he was also on e85
Old May 24, 2010 | 07:27 PM
DrivinVtec's Avatar
stock head. im not reving to the moon.
Old May 24, 2010 | 07:29 PM
DrivinVtec's Avatar
thats why i got the meth system. i figured that would be enough,
Old May 24, 2010 | 07:30 PM
DrivinVtec's Avatar
it wont make peek power..but im hoping i can reach my goal..
Old May 24, 2010 | 07:37 PM
90blackcrx's Avatar
That manifold is killing you more then you know, I just got my car ( h22 ) dynoed and partial tuned last week, and I must say if you had a better turbo manifold it wouldn't be an issue, but that manifold is killing the setup. Log manifolds aren't good, specially on an h22 head that loves to flow, these things love to breath. Send me an IM if you wanna talk about how my setup did.
Old May 24, 2010 | 07:46 PM
DrivinVtec's Avatar
well my original goal was 350whp. i made that. but now i want more. if i changed my manifold id have to change everything else. downpipe, ic pip, wastgate and so on. not really worth it to me to change all that. I did do everything my self but its not really easy. Ive seen people on make well over 400whp on a log.
DrivinVtec's Avatar
thanks for the pm..that manifold does look good man
Old May 24, 2010 | 07:52 PM
DrivinVtec's Avatar
http://www.p reludep ower.com/forums/showthread.php?t=275342
Old May 24, 2010 | 07:59 PM
viera's Avatar
my boy 88ED8 is making 430-450 on a stock motor. i dont see why not
Old May 24, 2010 | 08:01 PM
DrivinVtec's Avatar
log mani??
Old May 26, 2010 | 08:47 AM
Hawjap1gsr's Avatar
have you try tuning with someones s300 to see if you can play around more with the tune?
Old May 26, 2010 | 09:17 AM
PrecisionH23a's Avatar
The log manifold is why you are making such poor power. Your current manifold creates a lot of turbulence which in turn is creating exhaust reversion. Go with an 'equal length' style manifold and your problems will be solved. /thread.
Old May 26, 2010 | 11:20 AM
DC4KiD's Avatar
That manifold is definitely holding you back. My friend made the same WHP as you did with a ramhorn and the same turbo on 10psi (stock engine).
Old May 27, 2010 | 01:30 PM
DrivinVtec's Avatar
i posted a link with a log manifold and he did just fine.
Old May 29, 2010 | 05:50 PM
viera's Avatar
log mani??
no ram horn
Old May 29, 2010 | 09:39 PM
Blue94Accord's Avatar
I think you should try another tuner. 18psi seems very high for only 350hp.
H on boost all day!
Old May 30, 2010 | 11:20 AM
forcefedeg01's Avatar
H on boost all day!
i agree we made 349whp and 278tq @ 8psi bone stock internals, running t3/60-1 and lovefab mini me el manifold, 750cc's on s300.
Get the s300 and a better manifold, jeff evans made a comparison from log manifold to el manifold on his website and the numbers were remarkable. on a gsr but still the point of it
Old May 30, 2010 | 05:47 PM
DrivinVtec's Avatar
i have s100. is the s300 really going to make more power?i thought it just has more options but pretty much will tune the same?
Old May 31, 2010 | 04:37 PM
The S300 has more options, bigger fuel and timing maps and more. Theres nothing you cant do with the system. as for making more power, i dont see why numbers wouldnt change, your not gonna get 50hp by just switching it but a couple here n there is manageable. we went from neptune system to the hondata and just that alone after tuning went from 336whp to 349whp. nothing was changed at all just the system. car runs top notch and havent had a single issue with it at all.
all in all the s300 is a much better system than anything out there since nothing extra is required to run it, everything stays the same, no extra wiring nor sensors at all. check it out for yourself @ www.hondata.com and read on.
Old May 31, 2010 | 06:48 PM
092eg6's Avatar
what pressure plate?
delslow1975
Sep 23, 2011 01:30 PM
DrivinVtec
May 28, 2007 05:43 PM
VTECisSeXY
Dec 7, 2004 07:17 AM
paul93sir
Mar 17, 2004 06:04 AM
b_edson
Sep 9, 2003 01:29 PM
