blow by help
i have a h22a4 and it spits out oil from the breather. i was thinking it has bad rings, BUT compression test it and the cylinders read 190, 185, 180, 180. im using rc 310cc injectors with a untuned virgin p28 ecu(for now) since thats the only ecu i have that is compatible with the motor. tried chipping another p28 ecu to a h22 basemap but it lags ALOT. if anyone knows what is causing this PLEASE HELP!! thanks
your ring langs are starting to crack and eventually your gonna have a lot of blow by thats how my started after i added the turbo and didnt tune the car i used a piggy back, your gonna need new pistons and make sure you get it tune
thanks for the info jprelude92. i added the 4 cylinder engine restore and installed my own diy catch can. i drove it like i normally do and it doesnt seem to spit oil anymore from the breather to the catch can, but there is still a tiny bit of air blow out from the other side of the can tube that connects to the intake. any inputs?
