ECU Problem HELP!!
Old Aug 25, 2005 | 11:30 AM
slowsleeper's Avatar
Default ECU Problem HELP!!
I posted this in the hybrid forum but haven't gotten any replies so I'll try here.
I have a 95 Civic Coupe with a 93 JDM H22 in there. Its running on a stock p13 ECU and is running pretty rough and rich so I decided to plug in a chipped p28 to see if changing the ECU would help. I plugged in the ECU and turned the key to the ON position, and as I am looking things over, I see smoke coming from the p28...I quickly unplug the p28 and open the case and there was a lot of smoke coming from there. I plugged the p28 back into my other car that it came out of and it worked fine.
THe p13 also works to when i plug it in, it doesn't smoke or anything. I was wondering what re-wiring is involved when swapping in a JDM h22 into a Civic. I'm wondering if any of the terminal plugs to the ECU had to be rewired...because its weird that the p28 was getting fried and the p13 had no effect.
I also have a question on what can make the car run really rich..I am not too familiar with the H-series motor yet so any input will be appreciated. Thanks
Old Aug 25, 2005 | 11:49 AM
mtber's Avatar
Default Re: ECU Problem HELP!! (slowsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsleeper &raquo;</TD></TR><TR><TD CLASS="quote">I posted this in the hybrid forum but haven't gotten any replies so I'll try here.
I also have a question on what can make the car run really rich..I am not too familiar with the H-series motor yet so any input will be appreciated. Thanks </TD></TR></TABLE>
You probably have a plug mixed up or a wiring issue....
ThumperDumper
Aug 29, 2013 08:33 AM
$LiLPooky$
Engine Management and Tuning
Nov 19, 2009 04:01 AM
birwin12
Aug 3, 2007 10:21 PM
slowsleeper
Aug 26, 2005 07:30 AM
spoonhatchblack
Nov 4, 2004 10:12 AM
