LS/VTEC START UP
i just put my ls/vtec swap in my 92 honda civic si hb but it wont start. its just clicks once..
i checked all the fuses and they are all good..
i cant figure out whats wrong and was wondering if anybody could help me.
gsr head stock other then the skunk2 intake manifold.
b18b1 block-
oem 81mm pr3 pistons
ls rods with arp rod bolts.
new water pump,oil pump,timing belt.
gsr girdle
stock gsr tranmission
with oem itr clutch
b18b1 block-
gsr girdle
with oem itr clutch
prolly somethin simpler than you think.
check power to obvious components, starter, alternator, etc.
rotate the crank by hand to see if it spins freely. maybe ya dropped a tool in the motor or something. if you can't turn it by hand......
starter works.
ecu-p28 chipped with a pherable chip
will the motor spin by hand if it just got rebuilt ?
i check the power connection to everything already..
austinwasthere
Feb 13, 2014 07:41 AM
eGeeHaTcH
Jul 16, 2006 07:16 PM
