Guide Me Thru This Please (SOHC CRX)
Old May 18, 2010 | 11:53 AM
19C-Rex88's Avatar
Icon2 Guide Me Thru This Please (SOHC CRX)
This Is My First Honda And First Thread So Here I Go........... I Traded My Beautiful Truck Late 2009 For An 88 Crx hf With A d15b7 Already Swapped From A 92 Civic And A p28 Ecu ......Drove It For A While (With A BS Tag) And Then One Day Hauling *** Around A Turn, My Battery(Located In The Back) Flipped Over(Acid Everywhere) And The Car Died And Wouldn't Start. So I Flipped It Over And Beat It With A Screwdriver And It Started Right Up And I Headed Home. Next Day I Hopped In And Tryed To Start It, But It Just Made A Loud Clicking Noise. So I Investigated Just To Find That The Starter Had Cracked In Half! So Me Not Knowing What To Do, I Just Started Taking Everything Apart. Now Here Is My Problem. I Got A New Starter And Battery And I Need The People Of HT To Guide Me Thru Putting The Head,Starter,Wires,Etc. Back On The RIGHT WAY.I Am Really Excited To Start Building This Car And Learning Everything There Is To Know About Hondas. I Fell In Deeply Love With This Car And I Just Want To Drive It Again. So Please Help. P.S This Is What Ive Done So Far......(Striped It)...(Removed That Nasty Body Kit.....And Started Paintin
Old May 18, 2010 | 11:57 AM
bradennicely's Avatar
Default Re: Guide Me Thru This Please (SOHC CRX)
chilton manuel sounds like you rnew best freind
Old May 18, 2010 | 12:00 PM
8VEYBEYB's Avatar
its
hard
to
READ
YOUR
post
Old May 18, 2010 | 12:03 PM
19C-Rex88's Avatar
Well Ive Worked With Chevys My Whole Life....I Could Rebuild One Blindfolded(Not Sayin Much) I Really Just Askin Is This Around The Same Thing?
Old May 18, 2010 | 12:05 PM
19C-Rex88's Avatar
Originally Posted by 8VEYBEYB
its
hard
to
READ
YOUR
post
Sorry I Didnt Know It Would Be All Scattered Liike That.
Old May 18, 2010 | 12:13 PM
Aftermath_Hatch's Avatar
This is what I can tell you,dig through this site pretty much everything you wanna know is on here just use the search,and if it is not there just post it if we can help we will, are point you in the right direction.You will deal with smart *** like the post above,but most of us are here to try to give insite if we can. Anyway nice rex and good luck with the build!
Old May 18, 2010 | 12:18 PM
19C-Rex88's Avatar
Very Much Appreciated........I Guess Ima Research Call Some Friends Over And Take A Stab At It.
Old May 18, 2010 | 02:03 PM
johnnyonth3spot's Avatar
this is a good place to start
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Old May 18, 2010 | 02:09 PM
JDMkid413's Avatar
gl on the build and everything hope it all works out
Old May 18, 2010 | 02:42 PM
beansandrice's Avatar
One question. If you are an expierenced mechanic then what would tell you to remove a starter by taking the manifold and valve cover off? lol
Either way the starter removal is not that hard you already have the battery in the back you just need to unplug the single wire, unbolt the 12mm power then remove the 2 14mm bolts and out she comes.
Old May 18, 2010 | 06:34 PM
19C-Rex88's Avatar
I Took The Starter Off First...Than Vaulve Cover,Then Intake,Then Head......I Know Its Not Needed To Replace A Starter(I Was Just On A Roll) lol......At The Time I Was Thinking I Was About To Swap With A B20b Bought Right Before I Bought It, Someone Beat Me To The Buy. Now Its Biting Me In The ***.
Xynus
May 23, 2019 10:12 PM
danascavone
Aug 8, 2014 02:20 PM
FeJ9
May 24, 2008 06:06 PM
FalkenSiR
Oct 8, 2006 03:05 PM
