witch intake manifold should i use
whats the rest of the setup? power goal? are you going for peak hp or more of a mid-range powerband? what is your budget?
kinda hard to answer without more details.
well i got a sc61 turbo peakboost ramhorn 38 mm wastegate 81.5 ls block eagle rods cp pistons 3 inch turbo back exhaust b16 head with supertech valve springs and retainers and want to make like 400hp
ok that`s not what i asked i know this i am asking with manifold is the best to make power with that flows best i was thinking a cheap blox or a victor x unless someone else has a different one in mind
you ask a vague *** question...you want the best that is overkill for your setup or do you want a cheap *** blox, if you want something cheap a b16 manifold will support your goals, if you want to buy a manifold just because get a victorX, if you want something awesome, you can look into the kinsler or wilson manifolds.
well i dont have one at all now so i just want what is best for my setup i dont know what is overkill thats why i ask and those mesurements i gave dose that sound like a sc61
just run a blox for 400whp its a good all around manifold gives great driveability and power. the victor is ment for high reving big turbo and power applications
here's a good link that explains trim, a/r, etc
http://www.turbobygarrett.com/turbob...o_tech102.html
it sounds like you are describing the a/r not the actual wheel trims. the a/r does not have anything to do with the size of the turbo. are there any other marking or number on the turbo? is it made by precision? you may need to remove the housings and mesasure the wheels to get a definite answer
and i should just go with a blox?
blox will work fine for your setup. again its hard to say becuase there isnt really one thats "better" than others. oem, blox, skunk2, edelbrock...they will all meet your goals.
i think i will just go with the edelbrock b/c it has the vacuum line ports on the back side and a cleaner look imo
I use victor x there ported clean and yes clean vacuum ports and all even a 70mm bore! Ive had every intake you can imagine and thats been my favorite so far!
sikefcrx89
Jan 2, 2019 07:59 AM
TurboLaxx
Jan 13, 2006 10:07 PM
