Suggestions needed: B16 aftermarket Intake manifold options for my turbo needs/goals
So it's been a looooong time since I have actually done a turbo setup. (Last was a DOHC ZC Crx with some stage 2 exospeed regrinds,.63/.60 T-bird turbo and turbo edit) so its been a while.
Restoring my Em1 and want a little extra grunt. Bought the car and ended up having toasted main bearings. So b16 is laying here ready for something.
Plans include piston/rod combo utilizing stock sleeves.
Gt3076r .63 a/r for good response
Wanting to make high 3-low 400's
Will be using b16 head obviously
ITR cams
Supertech valve train with OEM retainers (Street Car)
rev limit will be where itr's stop making power. so probably 85-8600
Won't do any porting as it should not be needed for my power goals
My question revolves around the a2 intake manifold. Will this be sufficient for my power goals?
Would I need to swap out to say an ITR unit with matching ITR throttle body or is an aftermarket solution going to be best bet?
If aftermarket is going to be best best (I hate s2 or blox simply because of their business practices) All that really leaves is Edelbrock or some huge plenum GE style or custom units.
Being I live in the mountains with very few straights and hilly areas would the performer X be a better solution for my particular build even though I would say the victor X would probably produce more through the rev range?
If Aftermarket is best case scenario of course.
Any and all input is greatly appreciated.
And without pictures thread is useless
NEW UPDATE POST #28
ITR cams
NEW UPDATE POST #28
Moderator
re: Suggestions needed: B16 aftermarket Intake manifold options for my turbo needs/goals
I'm attempting to see what block you're using. I see you're mentioning B16 head, and what's being pictured looks like a B18B, was just going to be sure.
With the turbocharger you're planning to use, and the limited options that you've given. The EdleBrock Performance X is your first, best bet for the use of that turbocharger in either B16 or B16/B18B Hybrid form. The Performer X has longer runners for better torque management for your purpose of hillclimb, winding-road utility.
Those particular manifolds have a 66mm opening
Moderator
This is where I honestly like the Skunk2 Alpha, (Not to be mistaken for their Billet "PRO" Series Throttle bodies.) However, you don't like their practices, so the only other one I actually cared for was the Professional Products (Edlebrock private label) Cast Throttle bodies.
You can have the inlet of the PerformerX ported to match, as long as you don't cut into the IACV opening in the upper left corner, if necessary.
You're force inducted with a standard GT3076R at 52lbs/min. There's no need to go above 66mm anyway.
I see. Full B16A2 it is.
https://www.ebay.com/itm/Edelbrock-4790-Performer-X-65mm-Throttle-Body/200696626449?epid=178853147&hash=item2eba737d11:g: PtgAAOSw-0xYXX7u&vxp=mtr
I have also seen some used Accufab units and most others are just off brand super cheap worry about QC units.
May even look for a stock unit port matched to the manifold itself..
Swallow your pride and get a skunk2 alpha lol
there cheap and work good
Moderator
But I understand you're not wanting to use certain companies due to business practice and their ethics. The main reason why I'll never run ID injectors, Full-Race manifolds, or Brian Crower equipment. So, I get it.
Going to send a spare unit I have kicking around to maxbore and let him bore it out for the same price.
My .02, you will be able to attain your goals very easily with a oem b16 intake manifold and throttle body. That money would be better utilized elsewhere. If anything I would use an ITR intake manifold and throttle body. Nothing more for those moderate goals.
I like the tuna here
I have the Professional Products 66mm TB and I've got nothing bad to say about it, for what it's worth. Zero issues.
I was thinking about an ITR manifold but I guess I wait and see. Still gathering parts and pieces for the motor plus time to get the machine work and stuff that it needs done. I may just use the a2 intake/tb combo for now see what power/torque curve looks like and upgrade from there.
Acura 1994-2001 GSR/Type R - Throttle Bodies
im curious to hear about your position on ID, if youre willing to share
Moderator
Do they have authorized dealers now? Ebay is pretty slim picking for them and the professional products site only shows the part for a 68mm.
Because eBay. Automotive aftermarket companies no longer want their products associated with them due to their practices. They leave that to the dealers that wish to sell on eBay to deal with that.
The 66mm maybe discontinued except for old stock. Very few people got those.
Better off at Summit Racing. Best price you're gonna get for that, since they used to go through Nickel's...
https://www.summitracing.com/parts/p...iew/make/acura
It's turbo, honestly intake manifold and throttle body would be about the last mod I would add. I say leave them stock and just get it turbo'd. If you have a performance goal I'd start with a lighter car.
Car is mostly going to be a fun car to drive when I want. Don't need the car for any specific purpose. Maybe occasional visit to localish 1/8th,1/4 mile. Possibly even a fun visit to Summit Point just to do a few circuit runs. Nothing hardcore and not looking to race every muskrat,commode,charger I see,but the occasional drag someone's *** from a roll will be just fine for me.
Moderator
I age with skipping the intake manifold and TB altogether and focus on the right sized (smaller) DBB turbocharger so that it can survive ALL those purposes you've listed.
At least a good Koyo if not a files sized quality radiator. You need to pick your parts carefully for use in so many purposes. What you describe is so general, you'll easily go too far in one discretion if they're not careful.
