Can my block be re-sleeved? (pix)
Old May 17, 2010 | 12:45 AM
aleks77's Avatar
Default Can my block be re-sleeved? (pix)
hey guys just wondering if my block/sleeves are completely toast, or if i can throw some aftermarket sleeves into this? The red is where small chunks are missing, and the yellow is like hairline crack, very very small.
This happened at 21psi in 5th gear up a long hill (i know stupid!), my bottom radiator hose popped off and i lost like all the coolant in seconds. I guess my head lifted and combustion got into the coolant system and pressurized it? Thanks for any help!
Old May 17, 2010 | 02:45 AM
non-VTEC's Avatar
Default Re: Can my block be re-sleeved? (pix)
im sure it can easily be re-sleeved.
Old May 17, 2010 | 05:30 AM
dantamparacer's Avatar
Yes you replace that anyway
Old May 17, 2010 | 08:25 AM
aleks77's Avatar
can i just put a new headgasket on and run this as-is? The hairline crack is like 1" long, im just curious if its ok to run like 14psi on this, or will it crack more and more pretty quickly?
Old May 17, 2010 | 08:35 AM
kyden's Avatar
no, your sleeve is toast.
Old May 17, 2010 | 10:29 AM
ERL Performance's Avatar
I would want to see pics of it without the pistons in it so I can see exactly how far down the crack goes but it should be fine for us to sleeve. Let me know if we can help. thanks.
Old May 17, 2010 | 12:11 PM
PrecisionH23a's Avatar
ERL
Mikey3000
Jun 23, 2008 04:31 AM
integraboosted
Oct 13, 2007 09:20 PM
CO_CReX
Apr 29, 2007 06:44 PM
93(Civic)EG6
Nov 8, 2006 08:48 AM
XxslayerxX
27
Oct 19, 2003 11:33 AM
