help: installing 92-95 EG rear shocks on 96-00 EK
Old May 14, 2010 | 11:39 PM
blarue09's Avatar
Default help: installing 92-95 EG rear shocks on 96-00 EK
Question:
I am wondering if anyone can help me figure out how to go about properly installing these EG rear shocks on my EK?
I know the mounting fork is bigger to fit over the bigger LCA bushings of an EG so I need to fill the gap between my EK LCA bushings and the EG shock mounting fork.
I have heard of people using washers to do this but to me that method seems a bit crude.
Is it possible to get a properly sized metal bushing/spacer to fit perfectly, or is there any other proper method of doing this particular install?
Answer:
YES! Spacers can be ordered. Tokico dealers can order them as Part No. SPACER-1 and they come in packages of 2 spacers (2 needed per shock/one on each side of the rear lower control arm). A total of 2 packs are needed for 96-00 applications (4 spacers total)
So anyone wanting to install 92-00 or 92-95 (EG) shocks on a 96-00 (EK) can order these and not have to grab a bunch of flat washers to fill the gap around the LCA! This CAN be done properly.
Here is a pic of the spacers needed.
I will remove pic at request of owner if necessary
Last edited by blarue09; May 18, 2010 at 03:55 PM. Reason: increase readabililty (Q&A)
Old May 15, 2010 | 10:15 AM
eeek9's Avatar
Default Re: help: installing 92-95 EG rear shocks on 96-00 EK
I also want to know. there are some nice eg shocks i would like to pick up for my ek!
Old May 15, 2010 | 01:24 PM
Ef8crxsi4u2nv's Avatar
Well the Proper method would be to buy the Correct shocks for your car... Save yourself the headache and just do that
Old May 15, 2010 | 01:28 PM
Hello Bart's Avatar
only way i would think would be to change out the lower control arms... or just get the correct ones for your car.. i would prob. stay away from the washers...
Old May 15, 2010 | 01:29 PM
^Agreed. Do it right and get the right parts for your car
Old May 15, 2010 | 01:44 PM
blarue09's Avatar
well technically these shocks are for 92-00 according to tokico (illuminas)
but obviously they aren't the best fit for 96-00.
Has anyone here installed EG shocks on EKs?
Old May 15, 2010 | 01:49 PM
Hello Bart's Avatar
i have but i replaced the control arms and i did integra rear discs at the same time so i had changed everything out at the same time... and the struts were off an integra... same as civic..
Old May 15, 2010 | 04:06 PM
blarue09's Avatar
I found out that that tokico illuminas (92-00) and skunk2 pro-cs (92-00) come with fork spacers to fit 96-00 rear lower control arms. Mine however, do not have these so I have my local shop looking into getting the spacers alone.
I will update this thread if it is possible to do so. That way anyone else doing the same install can use the right parts.
Old May 15, 2010 | 04:17 PM
Hello Bart's Avatar
That is def. a good fact to know ... put pics on how they look...
Old May 18, 2010 | 03:50 PM
blarue09's Avatar
So the verdict is YES! Spacers can be ordered. See updated first post of thread
real_slow_EM1
Nov 8, 2004 01:54 PM
vizsual00
24
May 26, 2004 10:09 PM
vizsual00
May 14, 2004 06:50 AM
endlessdv
May 3, 2004 03:04 PM
acura_typer
10
Oct 11, 2002 05:19 AM
