hy35w holset turbo to big for my b16?
Old May 13, 2010 | 04:01 PM
naj_ej's Avatar
Default hy35w holset turbo to big for my b16?
hey guys, im from the uk and we dont have many ppl running hy35w holset turbo's so i guess a few of u guys must .
i can easliy get hold of hy35w holset turbo but would it be to big to run on a standard b16? not sure what they are rated at, but some one said to me they are rated almost same as gt35?
Naj.
Old May 13, 2010 | 04:38 PM
da_dude's Avatar
Default Re: hy35w holset turbo to big for my b16?
I running a hy35 on my d16z6. You should be fine. It's in between the t3/t4 57 and 60 trim.
Old May 13, 2010 | 06:30 PM
Bseriescivic5's Avatar
I run a T4, RHC7, a little bit bigger than the holset you speak of..... full boost by 4500 on my poor mans R. If you got it, run it. plenty of guys on here run that turbo.... venture over to the holset thread, lots of information.
Old May 13, 2010 | 06:46 PM
90dxhmt's Avatar
That will be perfect the 9cm housing will work well with the small displacement B16.
Old May 13, 2010 | 06:50 PM
95civhb's Avatar
it'll be beautiful on a b16... You could even run an hx35 on it.. no problem!
Old May 13, 2010 | 11:39 PM
joppe's Avatar
There is 54/58 hy35 and 56/58. Im running 54mm with dohc zc and full boost @4500rpm 3rd gear. 60mm wastegate...
Old May 14, 2010 | 12:48 AM
naj_ej's Avatar
cheers guys looking forward to getting it now
Old May 14, 2010 | 02:40 AM
naj_ej's Avatar
sorry another question, the flange that connect to the downpipe would i be able to use turbo elbow from t25/ t28? as to me the look like same flange style?
Old May 14, 2010 | 08:08 AM
joppe's Avatar
No it doesnt fit. 5 bolt holset has different pattern. I had t28 before hy35 and it didnt fit.
Old May 14, 2010 | 08:18 AM
naj_ej's Avatar
where would be the best place to get the downpipe made?
Old May 14, 2010 | 04:42 PM
naj_ej's Avatar
anyone ?
Old May 15, 2010 | 02:03 PM
spoolin turbo s's Avatar
just a local muffler shop is what i would do
good luck
i think that turbo is absolutely awesome for anything 1.5-1.8l, damn good bang for buck turbo, you just don't have the hotside AR options your stuck with 9cm and thats the only one that works for the hy35, whereas a hx35 is slightly bigger with tons of hotside options t3, t4, open and dividedtons of option with the hx35,hx40 turbo's when you want to set it up for more power and more lag than the hy35 then you can step up to those as they are a great bang for the buck as well
airforce21
Oct 7, 2009 01:26 AM
b16ajdmrex
May 23, 2009 09:20 AM
Benjithx
Feb 27, 2005 11:30 PM
7PSiEF9ZC
Mar 24, 2004 03:22 PM
