ls vtec a lot smoke
Old May 11, 2010 | 06:15 PM
ej1b18b1's Avatar
Default ls vtec a lot smoke
hi, i did an auto to manual swap on my integra and put an ls vtec swap the car was running good at the beginning but after a week or so it start smoking a lot from the exhaust is white smoke and when i step on it is with and black i did a com test and came 180 on all cyl its a bone stock ls vtec im still using the automatic ecu oil seems to be good with no coolant so i don t think its the head gasket i conect the vtec direct to a switch and it was working but now it doesnt work if somebody can help and give some advices.
Old May 11, 2010 | 07:31 PM
RedEG2's Avatar
Default Re: ls vtec a lot smoke
i would try a different ecu..
Old May 11, 2010 | 08:04 PM
LS/VTEC TURBO's Avatar
Do a radiator compression test may be your leaking a little bit of coolant into the motor.
Old May 11, 2010 | 08:25 PM
JDM215's Avatar
yea try a different ecu i was havin the same problem
Old May 11, 2010 | 09:09 PM
AcuraLsSE's Avatar
^ all the information is good. First I would get the right ecu and get it tuned. White smoke is transmission fluid or coolant. Black is unburnt fuel/carbon. The best way to see if your head gasket is working correctly is to use a kit that checks for combustion gasses in your coolant. I think a new ECU should fix your fuel problem.
Old May 11, 2010 | 09:11 PM
speedooo's Avatar
ls/v? untuned? smokes? unheard of.
Get it tuned.
Old May 13, 2010 | 06:08 PM
ej1b18b1's Avatar
ma car is going crazy. when i start the car it smokes a lil bit then stop and i ride for 1 or 2 miles with out smoke then the car choke and throw a big cloud of smoke then smoke for 1 or 2 min then stop ect....
Old May 13, 2010 | 07:51 PM
mouab18c1's Avatar
WRONG ECU WILL **** UP YOUR MOTOR. Quit driving it until you get the proper ecu
Imprezor
Jan 30, 2012 12:24 AM
carlossolorzano
Jun 29, 2011 12:30 PM
GilliesEK
Jun 22, 2011 03:40 PM
93egcoupe
Aug 20, 2006 08:06 PM
LSVTEC408
Oct 28, 2002 05:47 PM
