92 integra problem help!!!!!!
hi so here my problem i got dis 92 acura integra dat wont go above 3.5 rpm for some reason was fine b4 so now when i drive and it hits 3500 rpm it won’t go past it and when it does hit3500 rpm the car slows dwn and idk what is making it do this now so if you guys could help me out with this problem dat would b kool thix
Jumped timing? Bad distributor, ECU programing messed up?
Try resetting your ECU, pull the 7.5amp fuse under the hood, it's labeled Back Up
Check to see if your timing is right, if that doesn't work then try to swap out the distributor.
I don't think that would be the main problem, If your injectors were dirty then it would run really lean when getting into the higher rpm's if that was the problem causing not to go any higher and probably throw a code. Is it's throwing any codes? Happen to have a friend that would let you swap the distributor just to see if thats the problem.
ok so just ran it dwn the road and my rpms went lowe i hav 2 shif at 3000 rpm now and i dnt rlly wnt 2 waste my money on a new Distributor if thats not the problem
Anyone ever think his car might just be in limp mode?? And OP, have you ever changed out the fuel filter? Id also chick to see if "just maybe" the garment rings on the valve cover are leaking and oil is is grounding out the plugs?
heres da vid my little bro took of it runing was wanting 2 get it on vid show u but it was bck 2 normal heres my car its a work in progress http://vids.myspace.com/index.cfm?fu...eoid=104906318
Just clean off the door switch. All it is is a ground switch. But anyways,hope Ive helped you out and you get her fixed. I'm off to bed. I got to keep one eye closed just so i don't see double..lol Damd med. Good night.
