ok guys i got another problem please i need to figure out whats rong with my car
Old May 11, 2010 | 08:32 AM
logie4270's Avatar
Icon3 ok guys i got another problem please i need to figure out whats rong with my car
Ok guys this is my new problem I put gas in my car it dosnt wanna start and a check engine light comes on for a fuel injectior problem so after dissconnecting the battery for a few mins it will start right up and it allso has died on my driveing at 60 miles an hour just went from running to dead on the spot no sputter no nuttin so please help me
Old May 11, 2010 | 08:35 AM
EG_H22.'s Avatar
Default Re: ok guys i got another problem please i need to figure out whats rong with my car
sounds like it could be down to your ecu mate or dodgy wiring
Old May 11, 2010 | 08:41 AM
jimmy o.'s Avatar
My da did the same thing about a week ago check your grounds maybe or main relay?
Old May 11, 2010 | 09:14 AM
KINGVEM^^ED6's Avatar
Old May 11, 2010 | 09:23 AM
4g4dcruisin's Avatar
There is no CEL code for fuel injectors...there is only one for the fuel pump.
EDIT: you said that it died going full speed? It didnt stumble or just put out? It is possible for the fuel pump to cut off while driving, but the remaining fuel in the rail and injectors would be enough to let the car combust a few more times.
Old May 11, 2010 | 10:00 AM
logie4270's Avatar
It just died no sputter nuttin and it is a 91 honda crx its a little light on the ecu that flashes for the cel on them it was one long flash and six quick flashes that's cel 16 I'm guessin I asked my buddy who does a lot of stuff with hondas he said it is an injector code for it cutting out so idk but I really need help with figureing it out its my daily driver and I need it to b dependable for now so I can save some money for my build
Old May 11, 2010 | 10:01 AM
91GEDHATCH's Avatar
Check grounds man, anytime I have a wierd nonsense problem anymore, I kind of just assume it's electrical ha ha! Might not be but good place to start.
Old May 11, 2010 | 10:10 AM
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Hmm, i was wrong.
Old May 11, 2010 | 10:11 AM
What motor are you running?
Old May 11, 2010 | 10:16 AM
logie4270's Avatar
Its a d15b7 dual point injection the base model 91 crx
Old May 11, 2010 | 10:17 AM
Alright so you got a carb goin on...well that is out of my realm, cant help ya there.
Old May 11, 2010 | 10:20 AM
logie4270's Avatar
And what does that code mean? Does it mean a injector went out of what somebdy help me lol I need to get this figued out now
Old May 11, 2010 | 10:22 AM
logie4270's Avatar
I know it ****ing sucks lol I hate the dual point crap I'll am tryinto figure out how to use a obd1 intake on my crx anyone? If I can do that I should be good I hope
Old May 11, 2010 | 10:26 AM
You'de use an obd0 d16a6 intake manifold for your CRX. You would have to convert to MPFI, but i dont know how to do that haha.
Old May 11, 2010 | 02:28 PM
hatch_kidb18b1's Avatar
mpfi swap= EASY just search it and i have all the parts u need including obd1 injectors pm me if ur interested i have a write up also.i also have a good dpfi manifold that came off my car in perfect workin condition if u need parts pm me
aznoophi
Mar 30, 2008 01:06 PM
Ming Tsai
12
Apr 26, 2007 09:04 PM
czer47
Apr 8, 2007 01:05 PM
Jonknee
Nov 20, 2006 05:35 PM
civic89si666
20
Apr 8, 2006 05:26 AM
