Fuel pump?
Old Apr 6, 2007 | 01:36 PM
czer47's Avatar
Default Fuel pump?
all right guys I have a 91 integra with fuel problems and I have done everything to this cars fuel syestem except change the pump I wanted to know if there was a way to rebuild the fuel pump because I have no money at all and gott to go to a few job interviews so any help will work.
Old Apr 6, 2007 | 04:09 PM
VTEC_PRODUCTION's Avatar
Default Re: Fuel pump? (czer47)
why rebuild? is it broken? if there is no reason then dont do it...conserve your cash...then buy a high volume one...
Old Apr 7, 2007 | 07:44 PM
czer47's Avatar
Default Re: Fuel pump? (Acura_Integra_Type_R)
cee the problem is I have no cash and I need my car to get some money I guess I could sell 10 gallens thats in my tank 4 about 20 as high as gas is out here
Old Apr 7, 2007 | 07:59 PM
-Championship-'s Avatar
76.169.175.137
what exactrly is wrong with the car?...
is it throwing the CEL?
Old Apr 7, 2007 | 08:16 PM
czer47's Avatar
Default Re: Fuel pump? (CW_98gsr)
First About 2 weeks ago I noticed my car stalling and shuting off engine light came on ecu gave me a code 43 fuel syestem so I started searching 4 leaks nothing then I changed the fuel filter. It started running worse so about 3 days ago my car spettered like It had been and shut offso I had 2 push it home and it wouldnt start all three days so yesterday I started taking off the powersterring and a/c pieces and for ***** and giggles tried to start her up and walla it started but idels and rougher than it did when it died + I got fired early last month and have no income so I just need to get this car running decent long enough to find a job and get her fixed
Old Apr 7, 2007 | 08:25 PM
76.169.175.137
so when you said you did a complete over haul on the system except the pump, did you also change the injectors?...and what about the fuel rail?
might be something else, fuel pumps last along time before something gives in
Old Apr 7, 2007 | 08:30 PM
czer47's Avatar
well is there a way I can check the ingectors and fuel rail and possibly clean them
Old Apr 7, 2007 | 08:34 PM
76.169.175.137
you can just unscrew where they're connected to the rail and just plug it out and check.
Old Apr 8, 2007 | 09:42 AM
Sam92Teg's Avatar
There is also a Main Fuel Relay. MFR
Old Apr 8, 2007 | 01:05 PM
76.169.175.137
Default Re: Fuel pump? (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">There is also a Main Fuel Relay. MFR</TD></TR></TABLE>
forgot about the relays
touge killa
Sep 7, 2018 02:28 AM
IAteg
Nov 11, 2005 12:34 PM
mini-v-si
Jun 1, 2004 03:06 PM
rasta420
Mar 24, 2003 09:20 PM
