VTEC aint kicking in??
Old May 4, 2010 | 06:34 AM
Carlos 88CRXSi's Avatar
Default VTEC aint kicking in??
wat up guys i just fixed all my check engine light, due to code 14,10,21 and 6 my vtec should kick in but it doesnt i know my vtec selenoid works cause i alreaddy test it and it does click, i have a virgin pr3 ECU in my car, do you guys have any ideas about what could be wrong with it??
i would really preciate yourguys help thanx
Old May 4, 2010 | 06:57 AM
crx_si-r's Avatar
Default Re: VTEC aint kicking in??
what is your set up? who wired it up for you?
Old May 4, 2010 | 08:31 AM
igot a 94 gsr in it
i got the car like this but it had a **** load of check engines codes but i already fixed them i am not that pro at this **** my check engine light is off for now but vtec wil still not kick in
Old May 4, 2010 | 08:35 AM
KINGVEM^^ED6's Avatar
does it burn oil??
Old May 4, 2010 | 08:46 AM
no the guy who i got it from just rebuilted the engine probly has around 16k miles on it
Old May 4, 2010 | 08:49 AM
hmmmmmm
Old May 4, 2010 | 10:55 AM
WigginsSiR's Avatar
has it ever worked for you?
if not then maybe it never worked and you got ripped off?
just a thought
Old May 4, 2010 | 11:41 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old May 4, 2010 | 11:49 AM
just a thought
dude vtec does work i got the car for free from my unlce he bought if off an auction i know vtec works cause ive been running it with a switch
Old May 4, 2010 | 11:51 AM
Originally Posted by HondaPartsHero
thanx dude let me try to set this thing up
Old May 4, 2010 | 11:53 AM
per4mance's Avatar
You used a switch to make vtec work, wow hella smart man. Try putting cars together right before ghetto rigging it
Old May 4, 2010 | 12:57 PM
lunalink's Avatar
VTAAAAAAAAAAAAAAAAAAK!
Old May 4, 2010 | 04:07 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
X2 !!!
Old May 4, 2010 | 05:05 PM
crx_si-r's Avatar
seems to me you answered your own question. your vtec set up was never hooked up/wired in to work. especially since its being ran to a switch which is activated by shooting power to it. wire it up directly to the ecu, then let us know after its wired correctly
Old May 4, 2010 | 09:35 PM
ef_cowboy's Avatar
i had similar codes on my hatch and afer working out the wiring gremlins it work great
Old May 6, 2010 | 06:52 AM
i already hooked up everything my check engine is off, but still it wont kick in
do you guys think it may be cause the oil pressure aint good?? cause the oil pan looks a lil bent due to the car is low as ****
Old May 6, 2010 | 10:32 AM
LudeEFv2.4's Avatar
My old title sucked.
if the selenoid works and everything is wired correctly then vtec should engage. You are gonna do more damage running it with a switch, not to mention flipping a switch at high RPM is quite dangerous. The usual suspect when vtec does not engage is low oil pressure. CHeck your levels and pressure before you do any further harm. Check your grounds also.
Old May 6, 2010 | 04:34 PM
guitarguru87's Avatar
VTEC will not work if you are low on oil as well, just a thought...
Old May 6, 2010 | 09:32 PM
greenracer713's Avatar
make sure u have a good tach signal going to the ecu
Old May 7, 2010 | 05:34 AM
91efbluehatch's Avatar
do you have enough oil pressure?
Old May 8, 2010 | 07:27 AM
i dont know yet im about to install an oil pressure gauge, do you have any idea about how many oil pressure am i supossed to have or should be ok so it would work?
Old May 9, 2010 | 07:37 PM
big tex84's Avatar
hey, sry to hi-jack this thread but im having a similar problem, i am running an 89 std hatch, w/ b16a obd-0 swap, it has always run great, about a month ago i snapped the speedo cable ran around a couple weeks without it, but when i replaced it, vtec randomly works and when it does only for a few seconds. also my rev limit has dropped from 8200 rpm, to like 7800 rpm. i have no cel, or ecu codes. ive checked all my wiring, ive checked the solenoid, any ideas? i need my vtec!!!
chelsea
Sep 23, 2005 01:53 PM
TheIceMan
Aug 22, 2005 08:02 AM
springfieldcivic
15
Jun 24, 2005 02:26 PM
veilsides2000
Nov 27, 2004 11:18 PM
just4747
27
Oct 23, 2004 09:28 AM
