Valve cover gasket
Old Apr 21, 2010 | 04:01 AM
Domnificent's Avatar
Icon6 Valve cover gasket
I was told that i will need to have the valve cover gasket replaced and since i work at home depot im not rolling in cash. so my question is: Is the replacing this gasket hard? And How exactly do i go about doing so?
thanks in advance
Old Apr 21, 2010 | 04:13 AM
fiji's Avatar
Default Re: Valve cover gasket
simple, take off the valve cover get the gasket at ur local auto parts store like 20 dollars or something take the old one out then fit the new one in, simple
Old Apr 21, 2010 | 08:58 AM
b18bc3po's Avatar
Yeah probably one of the easiest things to replace just make sure you don't over tighten the bolts when your putting it back on, they have a tendency to break.
Old Apr 21, 2010 | 09:07 AM
RICKSAUTOMOTIVE's Avatar
dont forget the dab of honda bond on the corners by the cam caps
Old Apr 21, 2010 | 10:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Pick up some Permatex Ultra Grey sealant, same stuff as HondaBond.
Old Apr 21, 2010 | 10:59 AM
yes it is. i was just tooo lazy to type more than honda bond LOL
Old Apr 21, 2010 | 11:01 AM
Community Builder
heh yup, I've been using it myself for nearly 10 years and over 200K miles on my Integra with no problems. Much cheaper and easier to find at any auto parts store vs. actual HondaBond sealant.
Old Apr 21, 2010 | 11:23 AM
yeah when i worked at the dealer they told us to just charge a tube of honda bond to any car getting a valve cover gasket. i had so much hodna bond in my box i had to start taking it home. but thats the dealer for you
Old Apr 21, 2010 | 05:50 PM
thanks alot guys that was real helpful ima put this to use this weekend when i pop the head off
Old Apr 21, 2010 | 06:09 PM
Oh and i forgot, um i was told somthing about some springs or somthing falling when i take the head off.. could someone elaborate and kinda break it down as in what exactly do i need to do.. please and thank you
Old Apr 21, 2010 | 06:16 PM
if you do it right you'll be fine. just dont mess with the valve spring retainers. let the machine shop handle that. just pull the head
Old Apr 21, 2010 | 06:18 PM
mouab18c1's Avatar
Search google should have your answer. But If you are just changing the valve cover gasket you have no reason taking off the head. And even if you are taking the head off apart from the block. There should be nothing falling out of it unless its a fcuked up head.
Old Apr 21, 2010 | 06:58 PM
oh ok then.. i jus lookd up a vid about it on youtube and seen what to do but thanks alot for the info
rallyeredem2
Honda Civic (2001 - 2005)
Dec 25, 2014 10:58 AM
rasinhell
Aug 8, 2005 01:00 PM
type Gendy
10
Sep 6, 2003 10:44 AM
Qwikrex
Nov 18, 2002 02:13 PM
GSR44
Jun 20, 2002 10:14 PM
