starter problems after clutch swap
my starter acted stupid before the clutch change so when it didnt work after the change i just went and got a refurbished one from kragens auto parts...
(((the old one wouldnt spin, it would just pop out.)))
so, i put the new one in and it doesnt start!! it just clicks..
i didnt get a chance to check if it spins because it got dark out.
also are starters interchangeable between b series ??
also are flywheels interchangeable"????????
i basically had the same problem recently changed the clutch put everything back together and found out it was a lose ground check all your grounds and then try starting it cuz my starter would just click the same way you explained it
some friends told me he had the same problem too,
said he removed the starter and put a ground to it and had someone turn the key to check if the starter would spin. maybe the second time he attached the ground right. so it worked.
i guess ill check both too test the started and fix the grounds
i got it fixed. it was a wire. i moved my fuse box inside the car and i guess when i took off the starter i pulled on it too hard so it got loose on the inside where my tuck is at.
CiViC_SOHC
May 29, 2007 06:31 PM
EK k kay
Jun 19, 2006 10:25 PM
