b16 engine rebuild help!!
Old Apr 10, 2010 | 10:50 AM
xKAMILxEK's Avatar
Default b16 engine rebuild help!!
I would like to rebuild my b16 soon and i need some help to pick up parts
what should i get to get this done if you guys could help me.
i want to boost the motor once im done and still have some power before the turbo comes
let me know what you guys recommend to install and places i can get parts
thanks alot.
im interested in pistons cams and etc for the interials
Old Apr 10, 2010 | 11:58 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: b16 engine rebuild help!!
You should define a target goal in terms of power (or 1/4 ET) to have an idea of what you may or may not need.
Old Aug 4, 2010 | 09:45 PM
90SxyRxy's Avatar
im also rebuilding for turbo, i want to be around 300-350 Hp, i want to do it right, do i need to sleeve for that hp or will block guard be adequate, any machine work need to be done? should i increase the bore from 81mm? will forged internals alone be enough support? i have obd0 b16a...thanks for the help
Old Aug 5, 2010 | 04:19 PM
90SxyRxy's Avatar
bump
Old Aug 5, 2010 | 05:06 PM
DVDr's Avatar
Check out the dyno thread. You will see peoples setup with that power goal.
Then copy the setup .
Easiest way is.
Pistons
rods
hone block ( can leave it at 81 if you can )
good head gasket
your flavor of "real" turbo, the HX35 s working great. GT28rs , tdo5 . Many manyyy to choose from.
real manifold
and good tune again .
Old Aug 5, 2010 | 05:16 PM
phaphon's Avatar
i got some cams to help you and a intake manifold sk2 cams and a first gen only used for a month sk2 manifold
Old Aug 5, 2010 | 07:30 PM
90SxyRxy's Avatar
thanks for the input, what about sleeving the block, is it necessary, i figured that would be a great starting point? 8.5:1 or 9:1 cr which is better for what im looking for (350ish Hp)
Im pretty new to honda-tech, how can i locate the dyno thread?
Old Aug 5, 2010 | 09:19 PM
-__-'s Avatar
ARP head studs, rod bolts, pistons, rods, check bearing clearances
jachrist
Mar 9, 2010 09:20 AM
jdmekrobot
Mar 11, 2009 04:34 PM
De
Aug 1, 2008 07:23 AM
blackpearlcivic
Oct 9, 2005 04:58 PM
96EkTurboHatch
Aug 26, 2002 10:00 PM
