THROTTLE CABLE DILEMMA !
Old Apr 8, 2010 | 05:53 PM
FastLife617's Avatar
Default THROTTLE CABLE DILEMMA !
Alright guys hopefully you can shed some light on this issue i cant figure out what throttle cable was used previously before we took my motor out and did a make over and lost the previous one.
Car: 2000 civic si
Motor: LS/Vtec
Throttle Body is GSR with a GSR bracket
So far the cables i tried are GSR ..00 SI.. and H22 and they all to long! are OBD1 GSR throttle cables different from OBD2 ? im really confused on this.
Old Apr 8, 2010 | 05:56 PM
Anon51's Avatar
Default Re: THROTTLE CABLE DILEMMA !
nope. 94-01 GSR use the same throttle cable. afaik
Old Apr 8, 2010 | 06:02 PM
Added a pic ill try to get better once if needed
Old Apr 8, 2010 | 06:52 PM
Cortez_h's Avatar
Try a Type R cable and bracket it's shorter. Does your manifold have mounting points for a bracket? Can't see from the pic.
Old Apr 8, 2010 | 07:38 PM
Thats what i thought too just wanted to double check if there was a difference between OBD1 and 2.. and ill try to get better pix.. i was pretty sure i used either my original si one or a gsr one but i bought brand new once after i lost the previous one and they both too long the h22 one that i tried was the shortest but still a bit long
Old Apr 9, 2010 | 02:18 AM
Bump anyone one???
Old Apr 9, 2010 | 05:44 AM
apexi_rsx's Avatar
you can swap out the wheel the cable connects to. some are smaller then others if it was an auto or maunal tb. i had this problem for a while and had to exstend my cable becasue the manual one was so much smaller. worth a try i supose if u have other tb's laying around.
Old Apr 9, 2010 | 05:48 AM
Wish i did i would of tired but then again i had everything prefect last time before i took the motor out now that lost the previous one i cant figure out which one so i know theres one out there that fits lol
Would anyone know which is the shortest of them all ls..single cam once.. are they shorter?
Old Apr 9, 2010 | 07:31 AM
Red_Army's Avatar
pry like d15s.
can't you just cut the cable and throw a new ball on the end of it?
Old Apr 9, 2010 | 01:23 PM
ill see if i can get my hands on a single cam one
Old Apr 10, 2010 | 06:24 AM
Bump. Any one else?
Old Apr 12, 2010 | 06:02 AM
bump
Old Apr 12, 2010 | 10:27 AM
Cortez_h's Avatar
Type R cable would be your best bet.
Old Apr 18, 2010 | 12:23 PM
just tried one too long
highliner82
Dec 1, 2010 05:35 PM
SOHCrx
Oct 20, 2006 10:07 AM
crxowner
May 18, 2006 07:39 AM
whiteblurr
Jan 19, 2004 07:06 PM
hondaitegra
Apr 20, 2003 01:20 PM
