What Oil Should I Be Using?!?!
Old Mar 24, 2010 | 08:41 PM
SrVShayner's Avatar
Default What Oil Should I Be Using?!?!
Hey guys,
ive been researching for the last half hour and i cant really find exacly straight foward what i should be using.
i have a b18c1 with approx. 165 XXXkms, i just turbocharged it and about to put in all my fluids, tranny fluid, engine oil etc.
question is....
What are the best fluids/oil to get for my motor?
Thanks in advance.
Old Mar 24, 2010 | 08:52 PM
SovXietday's Avatar
Default Re: What Oil Should I Be Using?!?!
Personally I've always run Castrol GTX 10w40. Never really had any issues.
Honestly, for standard setups just use the quality oil of your choosing. I have NEVER EVER seen distinct performance or reliability differences from people changing oils in a common every day daily driver setup. As long as you use a good quality oil and change it regularly you should have no real issues.
Old Mar 26, 2010 | 06:46 PM
TEAM ASSASSIN SI's Avatar
i personally use penzoil 20-50 but i guess is a matter of personal preff.
Old Mar 26, 2010 | 06:55 PM
slvrlude's Avatar
Ive always used Mobil 1 high performance synthetic 10w30 in my b16 when it was n/a, and I still use it now that its turbo'd
Old Mar 26, 2010 | 08:10 PM
stiffdogg06's Avatar
How is that molasses doing ya?
http://www.ferrarichat.com/forum/sho...d.php?t=136052
Will be running Rotella 5W40 once the car is done. I wish I could find some 0W40 locally.
Old Mar 27, 2010 | 02:37 AM
rudebwoy's Avatar
castrol 5w50 synthetic, in my race car, castrol GTX 10w30 in my 00 SI daily driver, castrol GTX 10w30 in my odyssey. I guess I am a castrol man.
Old Mar 27, 2010 | 06:13 AM
Turbo-LS's Avatar
run rotella 10w30 or brad penn 5w30. both have zinc addatives which improves life of the engine and turbo and they have a higher thermal viscocity breakdown temp to handle turbocharged applications
i personally run castrol gtx 10w30 but switching to rotella on my fresh rebuild, its much cheaper than brad penn but probably not as good bt still better than conventional motor oil. and im not a huge fan of regular synthetics. to watery for me
Old Mar 27, 2010 | 07:01 AM
lyncoors's Avatar
quaker state because its 10bux for 5 qts at walmart lol
Old Mar 27, 2010 | 07:25 AM
dbsharp's Avatar
I run royal purple 5w30 in my car. I am really tired of paying that much though, been think of switching to rottella.
Old Mar 27, 2010 | 02:21 PM
Turbo-LS's Avatar
royal purple always makes my oil seals leak
imonx850
Jul 25, 2005 01:30 PM
v0lcom27
22
Jul 13, 2005 07:30 AM
handa
45
Aug 5, 2003 01:56 PM
Roadrnnr
Sep 5, 2001 06:31 AM
nEoMuGen
Jul 12, 2001 04:57 PM
