Killed my B16A del sol, help?
Old Mar 24, 2010 | 08:50 AM
mhohisel's Avatar
Default Killed my B16A del sol, help?
So I am a complete noob at engines, and I've spun a bearing. Took the head off, and the pistons and bearings out. Now what?
Do I just buy a new short block for a couple hundred? Or try and figure out what the hell I am doing and install new bearings myself?
Anyone know a good machine shop near maple valley/auburn Wa? My crank probably needs polished, and my #3 rod is chipped very slightly from the spun bearing. (if I run my thumbnail over it, its not smooth).
Also when I took the bearings out, I noticed some had a green mark on the edge, and some were brown. Problem is, I don't remember which cylinder had which color bearings! Am I fine with stock size on all? Or do I need to do something special?
Thanks guys and gals!
Old Mar 24, 2010 | 09:58 AM
ekftw's Avatar
Default Re: Killed my B16A del sol, help?
go buy some new bearing, get the cran micro polished, machine the rods to get the scoring marks off and have someone re-assemble it have them check for bearing clearance.
Old Mar 24, 2010 | 11:03 AM
98civdx's Avatar
Master Detailer
i would just get a b18c block, not really near you but intec and speedfactory are good.
Old Mar 24, 2010 | 12:20 PM
93egSLEEPER's Avatar
I use DG machine in auburn. I would have kevin at speedfactory in UP tacoma build your motor, good ****.
neil-ste
Feb 4, 2008 03:03 PM
OneBadTurboCRV
Sep 18, 2007 07:30 AM
made in JAPAN
Jun 11, 2004 08:59 PM
jdmhatch94
Sep 13, 2003 02:03 PM
P1mpSlap
Jun 25, 2003 10:32 PM
