Bearing Markings
Old Feb 3, 2008 | 02:14 PM
neil-ste's Avatar
Default Bearing Markings
I'm trying to get some bearings sorted for my b18c block, but the problem i'm facing is that the markings stamped onto the block are unreadable, like I totally can't make anythign out of them. I also don't have immediate access to any proper measuring equipment. Is there any way I can work out the size of the bearings needed from the codes stamped on the old bearings? I know the size of the journals on the crank, and I still have my old bearings, so would it be possible?
Thanks guys!
Old Feb 4, 2008 | 08:03 AM
neil-ste's Avatar
Default Re: Bearing Markings (neil-ste)
Anyone?
Old Feb 4, 2008 | 11:16 AM
4g hatch's Avatar
can you see the color markers on the old bearings.
Old Feb 4, 2008 | 12:34 PM
neil-ste's Avatar
Default Re: Bearing Markings (4g hatch)
Where are they? I have what I assume to be the part numbers off the back of them, is that what you mean?
Old Feb 4, 2008 | 01:43 PM
4g hatch's Avatar
not on the back or the front. look at the side[the thin part of the bearing].there should be a color on each side,green,brown,black. if you can see those then you dont need the markings on the block
assuming that the motor has never been opened up and there from the factory. if in doubt plastiguage them,never mind plastigauge them anyway
Old Feb 4, 2008 | 02:46 PM
neil-ste's Avatar
You're a gent It appears that I have 2 black, 2 green and 1 brown (which looks a bit orangey, I assume it's brown)
Thanks
Old Feb 4, 2008 | 03:03 PM
4g hatch's Avatar
yup,that would be a brown. just double check with the plastiguage
Leimokei
Sep 29, 2006 01:24 PM
hbyrd8701
Jul 28, 2006 04:24 AM
pcguy760
May 11, 2005 09:48 PM
1 Cam Wonder
Jan 24, 2005 08:29 AM
bunnyrabbit
Mar 29, 2004 05:20 AM
