Oil pan gasket
Old Mar 14, 2010 | 02:34 PM
GrenadaEG2's Avatar
Default Oil pan gasket
I just changed my oil pan gasket. How long does the Hondabond need to set before I can fill up the oil and put the engine back into service ?
Old Mar 14, 2010 | 03:08 PM
David12's Avatar
Default Re: Oil pan gasket
you can do it right away
Old Mar 14, 2010 | 03:18 PM
GrenadaEG2's Avatar
OK cool. I thouht you had to wait. The Hondabond says it takes 16 hours to set all the way. I dont want to end up with any leaks or have some of it drip of and clog up my pickup or anything.
Old Mar 14, 2010 | 03:48 PM
David12's Avatar
just let it run and get warmed up then lift it up and check for leaks, if no leaks drive it around the block and check again, you should be fine though
David12's Avatar
and your pan really shouldnt leak, even without the hondabond
Old Mar 14, 2010 | 04:11 PM
Ruben19's Avatar
no point of using hondabond if u have a gasket
Old Mar 14, 2010 | 04:59 PM
David12's Avatar
silicone does help adhesion if you are woried about it. I'm not sure about honda's but some manufacturers recommend using silicone to help seal the pan to the block. so it does help prevent leaks in cases of gasket failure
Old Mar 15, 2010 | 04:59 AM
GrenadaEG2's Avatar
I used a light coat of hondabond on both sides of the gasket. I put a little bit more in some places due to an issue wit the oil pan. It is a used Moroso pan that I picked up off someone here on HT and the damn thing was bent from being torqed down too tight or dropped or something. The first time I put it on I didnt think to check that and it leaked. Pulled it off an bent it back as best I could. Thats why I went a little heavy with the Hondabond in a few spots. No leaks now though.
Yuta
Nov 6, 2015 06:06 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
jrockets
Dec 3, 2006 03:34 PM
honda4674
Aug 22, 2006 09:56 AM
ringgold
18
Sep 20, 2004 04:28 AM
