Honda CR-V & Element 2WD & 4WD Element & CR-V
1st gen cr-v front & rear camber kit???
Old Mar 14, 2010 | 12:18 PM
alexeghatch's Avatar
Default 1st gen cr-v front & rear camber kit???
just got me and my family a DD project 99 cr-v 5 speed 4wd
stocking up on parts, ordered the ksport coilovers and want to do the camber kit but not sure off what car, it seems that from my research i can use 88-00 civic/ 94-01 integra rear camber kits but as far as the front i want to confirm that i can use the 96-00 civic ek please any info would be very helpful, thanks
Old Mar 14, 2010 | 05:22 PM
qwrty's Avatar
Default Re: 1st gen cr-v front & rear camber kit???
ive looked into this before but didint got a chance to do it since
ive installed an oem upper control arm form my stock, i think ek's
front camber kit would work, just look or take note of the bushings,
if you could switch it w/ a more sturdy or stiff/aftermarket ones...
it would be great, im just worried about the weight issue and play
that the stock ek camber could hold... as for the rear i boght ingall's
before.. it should work too..!
Old Mar 14, 2010 | 06:14 PM
Crx Jimmy's Avatar
If you want heavy duty ones look at the hardrace camber upper control arm. They are way more beefy than a skunk2 or any other eBay ones. You could also use the stock arm with the adjustable ball joint in it. That would solve any fitment issues.
Old Mar 14, 2010 | 07:49 PM
thank you soo much guys for your help i was looking into the ksport front and rear so everything would look good all orange matching the suspension...
also if anyone else has any experience please continue to build up on this thread...
Old Jul 19, 2010 | 10:05 AM
kurtdaniel's Avatar
if you could switch it w/ a more sturdy or stiff aftermarket parts specially with the Sway Bar Link..ksport is a very nice choice..im using it too..
Old Jul 19, 2010 | 01:11 PM
fast2camciv's Avatar
i used washers in the rear. works like any other honda, and cost me less than $10
i like having -camber in the front, makes for a well handling car.
Old Mar 28, 2023 | 08:21 PM
Jerusalem1414's Avatar
Did you happen to see if the k tune camber 96 - 00 civic fit the RD1?
Old Mar 28, 2023 | 08:22 PM
thumper64
Nov 8, 2009 02:46 PM
b-95pEk
13
Nov 27, 2007 05:14 AM
spoonishEJ1
Dec 14, 2004 10:43 AM
Denny
Dec 15, 2002 07:22 PM
mama
Jan 28, 2002 09:53 PM
