Alignment ques.
Old Jan 28, 2002 | 09:22 PM
mama's Avatar
New User
Default Alignment ques.
For the Ek is the rear camber adjustable? Cuz i dnt wnt to waste $$$ on 4 wheel alignmnt , if the rear are not adjustable. (no camber kit installed)
Thanx in advance for the answer
Old Jan 28, 2002 | 09:52 PM
HENRY's Avatar
New User
Default Re: Alignment ques. (mama)
the rear camber is adjustable if you get a camber kit or put washers on that upper control arm. Regardless, you should get a 4-wheel alignment after a lowering. I've seen the difference it makes.
Old Jan 28, 2002 | 09:53 PM
mama's Avatar
New User
Thanx Henry, that helps alot
JDKX
Suspension & Brakes
Mar 21, 2016 01:50 PM
shadohconspiracy
Suspension & Brakes
14
Apr 28, 2008 01:43 PM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
bartek_b
Oct 7, 2003 04:45 PM
