WG adjustment and boost ?
Old Sep 8, 2002 | 12:37 PM
TurbothisLS's Avatar
Default WG adjustment and boost ?
i have a crappy deltagate wg on my integra and I was wondering, before I start the car up for the first time with the turbo, how will i know what the wg is set on?
i have an electronic boost controller, but i'm not going to put it in for a little bit. how do i make sure it's at 7 psi or whatever before i start the car?
Old Sep 8, 2002 | 01:40 PM
Default Re: WG adjustment and boost ? (TurbothisLS)
anyone?
need help
Old Sep 8, 2002 | 02:07 PM
Old Sep 8, 2002 | 02:12 PM
Bnjmn's Avatar
boost gauge.....
Ben
Old Sep 8, 2002 | 02:19 PM
inspyral's Avatar
Default Re: WG adjustment and boost ? (Bnjmn)
You can back the spring out as far as it'll go if you want to start out on a lower boost level. Deltagates are usually adjustable to about 2-3 lbs. So you may only see 4-5lbs of boost with the spring backed out, and 6-7 with it all the way in.
Old Sep 8, 2002 | 09:31 PM
Default Re: WG adjustment and boost ? (inspyral)
so turn it all the way to the left to tune it to a lower boost setting?
rickturboteg
Aug 28, 2006 05:36 PM
pip9
Sep 24, 2004 09:17 AM
Quetzolcotl
May 24, 2002 01:30 AM
Snafu-Si
Mar 5, 2002 02:07 AM
accordfreak
Dec 25, 2001 12:20 AM
