Picking up a EG SI w/ 213k miles
Old Mar 11, 2010 | 07:05 PM
jyacoba2009's Avatar
Default Picking up a EG SI w/ 213k miles
This isn't my first car, but i'm just wondering since it has so many miles; what should i look out for that would be breaking, or needing repair soon?
i'd be doing regular things when i first get it, like flush the coolant, oil, and tranny. but other than that, i have no clue. any1 else got some good ol' suggestions? let me know!
mahalos
Old Mar 11, 2010 | 07:31 PM
jayWknight's Avatar
Default Re: Picking up a EG SI w/ 213k miles
Only way to know is to test the drive the car. Listen for unusual noises, look for oil leaks, body damage...etc.....
I bought my civic with 234k. The things I had to change were sparkplugs, cap, rotor, wires, oil pan gasket, cat converter (im in ca), rear trailing arm brushes, air filter and brake pads. Im currently at 246k and the car runs great.
Old Mar 11, 2010 | 08:13 PM
kzelisko's Avatar
At that kinda mileage most of the stuff that was going to go wrong probably already has, possibly twice. Whatever is wrong with it now, It's very possible that its the only major stuff you will have to worry about.
Old Mar 11, 2010 | 10:04 PM
ok, thanks thats good to know. but since it has such high mileage, what oil should i use? a 10w-30 or 5w-30, but like a high mileage formula? i use mobil 1 in my EK, but that only has 80k miles on it
Old Mar 12, 2010 | 04:15 AM
96hb's Avatar
That car has about as many miles as mine does, so I will tell you what I'm dealing with at the moment. Unless changed recently, the ball joints, bushings, and tie rod ends are probably all about shot by this many miles. Depending on the PO maintenance, it could need a timing belt and water pump, the exhaust could be rotting away, and it could probably use an alignment (especially after you replace all of the worn out bushings/ball joints I mentioned earlier). I would change the oil and tranny fluid, flush the coolant, get a new fuel filter, check the plugs, wires, dizzy cap and rotor, etc....Then just drive it. You should be able to spot the problems easy enough. Oh, the clutch master and slave cylinders could be on their way out also. Good luck with it!
Old Mar 12, 2010 | 06:34 AM
I've done only replacing my timing belt, fuel filter, plugs, and thats it.
How hard is it to replacing the ball joints, bushings, and tie rod ends? is that part of the axles? if so, in my EK i just replaced them since they made that squealing sound whenever I turned.
Old Mar 12, 2010 | 06:38 AM
thumper64's Avatar
upper ball joints, just buy the whole new UCAs. Lowers are easy if you use an impact wrench along with the tool from Autozone.
Old Mar 12, 2010 | 06:44 AM
lowers seemed a little confusing on where i was reading it, but uppers are just replacing the UCA?
and the exhaust rots? where should I expect it to rot first? I know i'll take a jack to it and expect it tonight when i get it, but is there usually a place for EG's where it is notorious to rot?
Old Mar 12, 2010 | 07:49 AM
miguel329's Avatar
quarter panel rot lol, take a magnet wit u see if any body filler on qaurter panels last car i bought was at night big mistake, went swap panels to black inside car, the owner before me decide to expandafoam the rot,then put bondo on it and painted it...
jnb0111
Oct 22, 2015 03:10 PM
Nocturnal
Jun 21, 2011 08:31 PM
rickkane
43
Nov 24, 2009 08:41 AM
Solo2Vtec
Honda Civic (2006 - 2015)
28
Jan 22, 2007 02:32 PM
caleb
Sep 6, 2003 09:52 AM
